Author Topic: Top Banana Challenger  (Read 43138 times)
Re: Top Banana Challenger
« Reply #120 on: April 13, 2007 - 10:02:39 AM »
do you have a link to Ulimate rides website ?
Offline Lunchbox
« Reply #121 on: April 13, 2007 - 01:14:54 PM »
Offline Confederate Cuda
« Reply #122 on: April 13, 2007 - 01:19:44 PM »
Do you know if Ultimate Rides attend Carlisle?
« Reply #123 on: April 13, 2007 - 02:16:54 PM »
So far, they haven't. It might be a good question to ask them thru an "ask the seller" on E-Bay. They might not know Carlisle is such a big market.
Offline Lunchbox
« Reply #124 on: April 13, 2007 - 05:09:44 PM »
They were at the NAT's last year  :dunno:
Lunch
« Reply #125 on: April 14, 2007 - 01:01:59 AM »
Thanks Lunch  :2thumbs:
Offline moparclown
« Reply #126 on: April 24, 2007 - 01:34:23 PM »
Heres the pic's I took of my BB stripe,remember this car was repainted but if you look you can see where the black is under the yellow in the bumper cavities.I hope this helps,The Clown
Offline Lunchbox
« Reply #127 on: April 25, 2007 - 01:26:25 PM »
Thanks Clown  :2thumbs:
As per request...
The dash stand is
2- 1x6x60"
2- 2x4x11"
2- 1 1/2" to 2" lag bolts
2- larger washers
The middle piece is a scrape 1x6" cut down to fit the height with a 1x4" split down the middle screwed to each side. I did it this was so that I could take the middle section out if needed or leave it in without have to flip the whole thing. The middle section probably isn't needed but thought it couldn't hurt. Also the passenger side 2x4" needs to have a slight notch cut into it so the bottom of the dash frame sits flat on the top of the 2x4.
Hope that helps
Lunch
« Last Edit: June 30, 2008 - 03:29:23 AM by Lunchbox »
Offline moparclown
« Reply #128 on: April 25, 2007 - 02:01:48 PM »
Your very welcome,your doing an awsome job Lunchbox.My little workbench just happened to be the right width to fit my dash,and it made it a pleasure to put it together.It doesn't show in the pic but it's bolted right to the bench.The Clown
Offline Lunchbox
« Reply #129 on: April 25, 2007 - 05:23:34 PM »
Nice   :2thumbs:  when things work perfect.
I am still waiting on my dash to get here from Ultimate Rides. Once I test fit it, the dash frame will be painted and work will start.  :cheers:
Lunch
Update
Got my new dash, it's pretty much the same as the first one, guess I will have to fix it my self.  :dunno:
« Last Edit: May 31, 2007 - 03:02:07 PM by Lunchbox »
Offline Lunchbox
« Reply #130 on: May 31, 2007 - 03:11:50 PM »
Well I have been working on on my cowl and I just can't seem to get this thing together. I am having trouble with welding this piece in. I am using a Miller 175 mig welder. The wire thickness is .023". Seems when I try to make this weld I am either burning thorugh or puddleing on top. I am also doing a bunch of tacks, should the whole thing be attached with tacks until its solid, or can you run small beads? I am trying to do a butt wled is there a different way I should be doing this? It is also warping, no matter how slow I go and let it cool down. Lastly some of the welds look as if there is a weld on the opposite side of the panel like to much heat or to much wire speed maybe both.
Any tips would be greatly appreciated.
Lunch
« Last Edit: June 30, 2008 - 03:30:39 AM by Lunchbox »
Offline conv340
    • Myspace CaMopar
« Reply #131 on: May 31, 2007 - 11:25:10 PM »
Man I love this site. Where else can you go where people think they can save rusty old Mopars and call it fun! I feel your pain with welding this stuff. E-body's seem to have a high alloy mix it the steel nickel? But it welds like spring steel. I have been doing "some" myself  ::) I use .030 and a different model miller but its the same. Practice a little on some original steel you cut off. I use wet rags along the weld and just move them away from the spot your tacking. Have Patience lots of little tacks then let it cool. But welds are the best but hardest. If you overlap it's a lot easier. I have the same bead roller it can do flanges also. I do but welds if its highly visible or visible on both sides. Then cheat on the rest  :nono: Just make sure you can get seam sealer on the back if you overlap so no rust! And yes on sheet metal I just keep tacking untill its solid. skipping around to avoid heat. If the part has a good contour it won't warp so easily and you can do little 1/4 inch welds. I'm no expert, just a glutton for punishment. I think I have a mile of weld by now  :eek4: Keep up the good work.
Two models, Two makes, One year, One body.
Offline 360 'CUDA
« Reply #132 on: May 31, 2007 - 11:42:18 PM »
I try to cover the back of the two panels being welded with a piece of copper, duct tape it on there to help keep Oxygen from leaking in through the back heating the weld up too much.  In some cases you can use a piece of copper pipe if the area being welded is straight enough. The copper keeps the O2 away but the weld wont stick to it
Also, squeeze the MIG gun trigger a little to let the inert gas form a little airless bubble and then pull the trigger back all the way for the tackweld. That keeps the O2 away also.
Offline Lunchbox
« Reply #133 on: June 18, 2007 - 02:42:12 PM »
Thanks for the tips  :2thumbs: I had to take a little break for some other commitments but will be starting back up on the metal work again shortly. I did spend a day and make a body cart so I can wheel it around the shop a little bit easier. Next will be a rotisserie.
Lunch
« Last Edit: June 30, 2008 - 03:31:10 AM by Lunchbox »
Offline Lunchbox
« Reply #134 on: July 01, 2007 - 03:35:08 PM »
Well I got back to working on the cowl again. I am really starting to get the hang of the sheetmetal work. Its kindof relaxing now that I can put stuff together that works and doesn't totally look like crap. On the inside little bumps of weld cam thorugh the other side and between some of them you can see a slight gap from the butt welds. Should I leave as is or should I flip it over and fill the 10 or so gaps I have. The gaps are only on the back side not the fornt. Sorry no pics of that.
Lunch
« Last Edit: June 30, 2008 - 03:32:58 AM by Lunchbox »
