Author Topic: Top Banana Challenger  (Read 43148 times)
Offline Challenger6pak
Re: Top Banana Challenger
« Reply #60 on: January 24, 2007 - 05:12:30 AM »
Your car is going to look great!!!
Offline Super Blue 72
    • Phil's Super Blue '72
« Reply #61 on: January 24, 2007 - 08:09:17 AM »
Very nice model mock up!  Nice job on the bumble bee stripe!  :thumbsup:
Offline Lunchbox
« Reply #62 on: January 25, 2007 - 04:25:41 PM »
Well I was going to work on the cowl today but instead I finished up some other work I had to do on two other projects. Here is a couple of pics of my DS inner fender I removed about a week ago. This weekend I will hopfully have the cowl off the car.
Lunch
« Last Edit: June 30, 2008 - 03:07:39 AM by Lunchbox »
Offline Lunchbox
« Reply #63 on: January 28, 2007 - 01:43:29 PM »
I got some more work done this weekend. Removed the other inner fender along with the cowl. The inner fender was easy but the cowl was a pain along the windshield line. Once you drill the spot welds there was not way to get a blade behind it to pop any stubburn welds left clean off. Got it done though.
Heres some pics.
« Last Edit: June 30, 2008 - 03:09:01 AM by Lunchbox »
Offline 74chall
  • Mopar or No Car
« Reply #64 on: January 28, 2007 - 04:27:19 PM »
NICE WORK!  :2thumbs:
Offline Lunchbox
« Reply #65 on: January 28, 2007 - 04:46:46 PM »
Thanks it was kindof scary at first but then it got better and better. The cowl and the rear seat are going to the blaster this week so I can see the damage that I will need to repair.
The second to last picture shows the sealer that was between all the joints. It looks like it was applied then the two pieces were then welded together.
Does anyone know wha stuff to use to replicate the factory process?
Thanks
Lunch
Offline farmboy70
« Reply #66 on: January 28, 2007 - 06:06:58 PM »
Try using a good weld through primer and coat the hole thing in a product like POR-15 or Rustbullit before welding (not the weld seam).This will give you much more protection than the spongy type sealer that the factory used. It holds water and is why it rusted to start with along with no paint protection.
Looks like you are moving right along , those cowl welds are a pain!
Offline Lunchbox
« Reply #67 on: January 28, 2007 - 06:14:28 PM »
Thanks Dave  :2thumbs:
All your help has got me here and is keeping me going.
I have the weld throught primer (SEM)
I also have a product called Zero Rust that Resto Rick sells. I belive it is along the line of a POR-15 and/or a Rust Bullet. I have read many bad things about POR-15 and heard first hand from several body shop guys  :dunno:
One problem I have is the corner of the window. The rust has come down that and got under the firwall as well. Not sure what to do there, lots of compound bends to try and re-create, any sugestions?
Thanks
Lunch
Offline farmboy70
« Reply #68 on: January 28, 2007 - 06:27:41 PM »
Post a picture of the area I'm guessing it is the same area I  replaced on mine (first couple pages in my post) On that one I had a donor piece to use.Let me know how much of the area you need I may have a piece to use.
Offline farmboy70
« Reply #69 on: January 28, 2007 - 06:29:09 PM »
Probably here?
Offline Lunchbox
« Reply #70 on: January 28, 2007 - 06:36:41 PM »
I know its bad for sure in the red circle between the layers of the a-piller and the firewall. Im sure it will be bad around the yellow circle once I blast it a little this next weekend.
I will get some better pics next weekend when I work on it again.
I will let you know  :2thumbs:
« Last Edit: January 28, 2007 - 06:44:20 PM by Lunchbox »
Offline farmboy70
« Reply #71 on: February 03, 2007 - 05:51:25 AM »
I checked my parts and I have these if you need them. Shoot me a PM if you want them, one side has a small hole but it is in the flat area so it maybe easier to fix.
Offline farmboy70
« Reply #72 on: February 03, 2007 - 05:52:35 AM »
 :stomp: Man my pictures stink lately!!!
Offline Lunchbox
« Reply #73 on: February 04, 2007 - 10:24:10 AM »
Got some ore work done this weekend. We got the both built for the blasting area. We made a simple 2x4 frame then used plastic and duct tape to seal it all up. I bought a compressed blaster for about $100 bucks and 200 lbs of black sanding media.
There was a slight learning curve with the blaster but once we figured it out it worked pretty good. We borrowed a help from a guy that made a halo out of felxible rubber hose. The halo had a buch of holes in it around the circumfrence. Then when I was blasting hooked it up to a air hose running 15 psi, kept the dust out of the helmet. The take would hold 50 lbs of media and it would take about 15 minutes to blast thorugh it all. Then I would take a break to let the dust settle down a little bit. We are going to make a better door for it and maybe hook up some filters and a fan to help keep the dust down a little.
Heres some pics you can view the before pics above.
Lunch
« Last Edit: June 30, 2008 - 03:11:38 AM by Lunchbox »
Offline Lunchbox
« Reply #74 on: February 04, 2007 - 10:31:23 AM »
Here are some pics of the few bad spots we found. Not very many pin holes but will easily be fixed with the MIG. There was some pretty bad pitting around the cowl vent area. The blasting would only get it so good in some areas leaving some of the deep pits (black in the picture). Is this okay to prime over or should I cut it out and put a new piece in?
Lunch
« Last Edit: June 30, 2008 - 03:12:28 AM by Lunchbox »
