Today's progress was the trunk pan , drop extensions , weather strip panel. Still a lot of trimming and fitting to do for the tail light panel and I left the lower part of the quarter panels loose to fit the splash pan. The trick to in stalling the drop extensions seems to be to rework the front triangle area where it meets the wheel house. It seems to be bent about a 1/2 inch on the long side. Once that was re-bent they fit in pretty well. A lot of edge trimming to do yet but coming along.
The first picture shows the outline of the frame rails with the pan laying in the trunk, I take a paint dauber and mark the out side of the rails and then dab where the original spot welds were. All that is left is to drill the holes for plug welding. After all that marking I only missed on three holes, not too bad.
Tomorrow it's on to the tail light panel, this will take some time , it had been brazed on from a replacement from the accident and needs a lot of rebuilding.
One bone head move I made was to forget to install the jack mount on the left wheel house before installing the quarter
,that made for a lot of finagling to get in and weld.
