Author Topic: How do you ge the knobs OFF!  (Read 1348 times)
Offline CUDA JAS
  • vroooooom!
« on: October 28, 2006 - 11:37:03 AM »
The knobs on the dimmer switch and wipper switch on an E body Cuda, how do you get them off???
Jas
 :canada: :burnout:
74 'cuda 360/727
Just call me a gearhead!
Re: How do you ge the knobs OFF!
« Reply #1 on: October 28, 2006 - 11:42:57 AM »
PULL
« Reply #2 on: October 28, 2006 - 12:51:34 PM »
Hard
Offline CUDA JAS
  • vroooooom!
« Reply #3 on: October 28, 2006 - 02:12:00 PM »
74 'cuda 360/727
Offline RusTy/SE
  • Just havin' fun
« Reply #4 on: October 28, 2006 - 04:53:44 PM »
I think this thread should be moved to the Classics Section...just 'cause  :smilielol: :smilielol: :smilielol:
Russ
2001 Durango     1B4HS
1970 Challenger  JS29U
Offline CUDA JAS
  • vroooooom!
« Reply #5 on: October 28, 2006 - 07:46:44 PM »
Hey, I tried pulling, and hard....but they did not come off...
It is funny though!! :wave: :cooldancing:
74 'cuda 360/727
« Reply #6 on: October 29, 2006 - 06:58:45 AM »
CURSE
Offline JayBee
« Reply #7 on: October 29, 2006 - 11:42:21 AM »
Keep trying  :pullinghair: we're all pullin' for ya
John
1970 Barracuda convertible
2014 Toyota Avalon
Offline duodec
« Reply #8 on: October 29, 2006 - 01:43:26 PM »
Pull straight back.  Try to support as much of the rear of the knob as possible with your fingers or a tool that will do the same.  Don't put too much 'squeeze' pressure on the knob; they are old, and in a Desert car (mine lived in Nevada most of its life) can get brittle enough that the squeeze will crack them.  Also can be helpful if the knobs are warm (sunny day warm, NOT hot).
Some knobs have a metal flat spring in them to provide grip against the switch shaft; cars from humid climates might have rust in there that makes removal very difficult without causing damage.  Unfortunately the two penetrants I tried on switches in swap meet instrument panels that had the rust problem (bought here in Ill Annoy) caused discoloration of the knobs (that was WD40 and Kroil).
Offline CUDA JAS
  • vroooooom!
« Reply #9 on: October 29, 2006 - 03:14:02 PM »
woooohooo got em, man did I have to pull...
I hd to use a pair of pliers on the windshield wipper knob (very gently) to get it off!!!!! :faint:
Thanks guys!!1
74 'cuda 360/727
