Author Topic: 7.25 to 8.75 conversion - need new spring shock mount plates?  (Read 1358 times)
Offline OzCuda
« on: October 29, 2006 - 04:06:53 AM »
Replacing the 7 1/4 with an 8 3/4 diff and the axle tube is bigger diameter and will need to get bigger u-bolts.  Therefore I suppose I need new rear spring shock mounting plates as well?  Can someone confirm that there are different sizes available and where to buythe right ones??
Also, while I'm on the topic of the axle conversion, will the brake assembly be a straight swap from the 7 1/4 to the 8 3/4??
« Last Edit: October 29, 2006 - 04:09:42 AM by OzCuda »
'70 Barracuda
Re: 7.25 to 8.75 conversion - need new spring shock mount plates?
« Reply #1 on: October 29, 2006 - 06:38:26 AM »
Just Suspension lists only one replacement probobly for the larger dia.  :dunno:
http://www.justsuspension.com/shockmount.htm     kinda pricey  :clueless:
« Reply #2 on: October 29, 2006 - 01:39:40 PM »
yes ypu need different ones & Mopar sells them as well
« Reply #3 on: October 30, 2006 - 02:23:48 PM »
You definitely need bigger plates. Some genous had the 7 1/4 plates on my car. They ever so cleverly bent the U-Bolts to fit into the shock mount plate holes.  :swear:   :horse:
Offline OzCuda
« Reply #4 on: October 30, 2006 - 03:50:45 PM »
OOPs, that option was discussed this morning as a potential fix, as was extending the holes in the plate to take the wider u-bolts :-[
If only parts were more readily available here it wouldn't be a drama.
Anyone have an answer about the brake swap????
'70 Barracuda
« Reply #5 on: October 31, 2006 - 03:49:13 PM »
yes the brakes will swap over , the backing plates all have the same 5 bolt pattern in them
Offline Jacksboys
  • Here Since 08/28/06 GEORGIA
« Reply #6 on: October 31, 2006 - 09:21:10 PM »
That is the best news.  I was just about to ask that, thanks Chryco.
Also for the mounting plates, you may want to check this website (cheaper):
http://chucker54.stores.yahoo.net/respshmopl.html
Offline OzCuda
« Reply #7 on: November 01, 2006 - 05:13:52 PM »
Thanks for the info guys.  Good news about the brakes too :thumbsup:
I have some old plates coming that are off a Dodge Phoenix which was sold here in Australia.  Sight unseen but description sounded close so will just have to wait and see - otherwise the Mancini plates look like good value.
'70 Barracuda
Offline 1 Wild R/T
« Reply #8 on: November 01, 2006 - 05:49:42 PM »
B,C & E body plates will work...
