Hey Guys I picked up a new third member 742 case, sure grip and 3;23's $250 didn't think that was bad.. anyway I put it in the cuda. And It seems tight... way to tight It acts like a spool. when I turn a corner the wheels will chirp and the back of the car will bounce and shimmy a little. So I pulled it out and took it apart.. I have a maual and it shows there being 5 clutch plates on each side.. mine has the 5 plates but each side also has a thin shim.. could somebody have put these in to tighten it up?? do you think If I were to take the shims out it would help my problem? thanks Brandon
