Author Topic: Tuner Question  (Read 1077 times)
sleepychallenger
Tuner Question
« on: October 29, 2006 - 08:10:15 PM »
Hey all,
I just want to check with you on my thoughts. I am rebuilding a 1.8 from a 2003 Corola for a freind and when I checked it before opening it up it was puffing smoke out of the oil fill and vent tube. My thought was bad rings because it has to be coming from the crank case. I checked the compression and it was 75% less than the other cylinders. My thoughts are that the #3 rings are bad but when I took them out they looked just fine. Could the problem be something that small that I cant see in that cylinder or on the rings? Any thoughts would be appreciated.
 :clueless:
Offline Jacksboys
  • Here Since 08/28/06 GEORGIA
Re: Tuner Question
« Reply #1 on: October 29, 2006 - 10:25:15 PM »
 :clueless:
Could it be a blown head gasket?
 :clueless:
Re: Tuner Question
« Reply #2 on: October 29, 2006 - 10:44:28 PM »
the rings could have been overheated & lost their tension
Offline 360 'CUDA
Re: Tuner Question
« Reply #3 on: October 30, 2006 - 08:46:15 AM »
It's not this one is it??   (an original wing car)   :naughty:
Offline Super Blue 72
    • Phil's Super Blue '72
Re: Tuner Question
« Reply #4 on: October 30, 2006 - 09:30:26 AM »
You might want to go on some Toyota forums and ask.
My friend mentioned to me a while ago that the Toyota 4 and 6 cylinder engines have an inherent issue with sludging of the oil due to poor crankcase ventilation.
This will lead to premature contamination of the oil then premature wear, ie the rings, therefore decreased compression.
Check this interesting article.
http://www.toyoland.com/sludge.html
Hope this is useful!  :thumbsup:
sleepychallenger
Re: Tuner Question
« Reply #5 on: October 30, 2006 - 08:14:54 PM »
thanks for the replies. it wasnt the head gasket, checked that thouroghly. I dont think that I mentioned that this is a stock 4 cylinder that he had BOOSTED 14 PSI
Offline Jacksboys
Re: Tuner Question
« Reply #6 on: October 31, 2006 - 02:55:37 AM »
Then I would have to go with:
