Author Topic: 1969 Cuda 6 Barrel?  (Read 1715 times)
Offline focal 7
1969 Cuda 6 Barrel?
« on: October 30, 2006 - 10:57:28 AM »
I just bought a 1969 Barracuda 340 Formula S car. In decoding the fender tag it shows the E55 option. In the decoding site I'm using it says E55 is a 340-6 Barrel. I'm confused, I didn't think there were intakes like this in 69' What's the scoop? While this car does have the matching #'s motor, it is simply a cast 4 barrel manifold with carb. What does it mean 6 Barrel?       Thanks  :clueless:
Offline Culvers
Re: 1969 Cuda 6 Barrel?
« Reply #1 on: October 30, 2006 - 03:24:46 PM »
In 1969 E55 was the standard 4bbl, only in 1970 it was the 6bbl. (Six Barrel = only AAR Cuda)
« Last Edit: October 30, 2006 - 03:29:15 PM by Culvers »
71challengher
« Reply #2 on: October 30, 2006 - 04:29:51 PM »
And Challenger T/A
Offline Culvers
« Reply #3 on: October 30, 2006 - 04:34:54 PM »
No! Challenger T/A = Six Pack :bigsmile: (but also E55  ;))
Offline Super Blue 72
    • Phil's Super Blue '72
« Reply #4 on: October 30, 2006 - 06:05:25 PM »
Actually didn't E55 just mean 340 engine?  :clueless:
There were 340 4 barrel engines then there was the Trans Am option which had the 6 pack set up.
6 Barrel was Plymouth's equivilent of Dodge's 6 pack, whick could be had on 340 + 440 engines= 3  x 2 barrel carbs.
Alaskan_TA
« Reply #5 on: October 30, 2006 - 11:28:35 PM »
E55 does mean 340 in 1969, 1970 and other years.
For the 340 sixpak you have to look for the A53 package code. (1970 only)
A53 was a code in other years with different meanings, but not for the T/A or AARs, so as far as the 340-6 goes it was 1970 only.
Barry
