Needing some numbers decoded for me please.
This 340ci engine is currently in a 1971 Cuda and as far as I know it's not the original engine.
Drivers side - HM-340R - 36730074 (Hamtramck low compression 340 (R = Regular gas) But what does the 8 digit number mean? I was thinking the 3 = 73? and it was the 74th engine off the assembly plant that day?)
Drivers side - 27809-30-340/6 (It means a 1968-73 LA 340, correct? So, what does the 340/6 mean, can't be SIXPAK being low compression or?)
Passengers side - 6-30-70 (This is the 30th of June 1970, right? If so, why is it a low compression engine? Did they make low compression 340's in 1970?)
4-Speed Numbers - PP-833-3581-002 and below that 99129H (I have no idea, can't find it in any of my books)
These are the numbers from a friends 'Cuda. I asked him to double check his numbers and he seems to think they are exactly what is on the drivetrain pieces. Thanks for any help or input into the matter.
Regards,
NZ
