Author Topic: CHryco Buddy,got a ?.833  (Read 1681 times)
Offline moparnut
    • My Photo's
« on: October 31, 2006 - 05:06:13 PM »
WHich would be a better choice in putting behind a 440 an A833(non hemi)or an A833OD?
is the OD unit stronger or weaker?
thanks
2012 Subaru Forester
70 D100 Adventurer 383 pickup
06 Honda VTX1800S Spec 3
Re: CHryco Buddy,got a ?.833
« Reply #1 on: October 31, 2006 - 06:29:00 PM »
the Od is weaker whatever that means , I had the od in my Duster for 9 years dumping the clutch at 5500-6500 RPM it broke numerous 8 3/4s but never hurt the tranny  , you wnat a n earlier OD though , the later OD had less splines on the syncro hubs , still never seen one fail though
The od does use a larger case & brgs so it is tougher than most 23 spline trannys
« Last Edit: October 31, 2006 - 06:32:35 PM by Chryco Psycho »
Offline moparnut
    • My Photo's
« Reply #2 on: October 31, 2006 - 06:32:24 PM »
thanks,I have an aluminum OD and a standard 833,guess the 833 is a better choice?or would you not put one behind a 440 no matter what?
« Reply #3 on: October 31, 2006 - 06:33:36 PM »
either would live behind the 440
Offline moparnut
    • My Photo's
« Reply #4 on: October 31, 2006 - 06:42:22 PM »
ok but i forgot to tell you I'm running nitro,now what?Kidding
thanks
Offline moper
« Reply #5 on: November 02, 2006 - 09:47:23 AM »
The aluminum case versions have had issues int eh past uynder high horsepower with teh counter gear shaft loosening up in it's bore. I've never seen it myself, but I have read about it. That being said, I doubt you'll even break one unless you stick in a Dana and run slicks. Iron case ODs can be found for like $30-50 around here.
« Reply #6 on: November 02, 2006 - 06:13:59 PM »
I did have steel bushings machined into 1 Alum case I used for a short time , buyt never had a problem so far with the countershaft pounding down in the case
