Author Topic: 71 340 Challenger Value?  (Read 2304 times)
Offline 71_340Challenger
« on: November 03, 2006 - 02:03:53 PM »
Money has recently gotten very tight and I am having to consider selling my 71 Challenger. The specifics are:
71 Challenger Coupe
Have original, #'4 matching 340/727 tranny, but both need to be rebuilt
Rebuilt and installed a 440/727 from a 76 New Yorker
   *Block, crank, heads cleaned, magfluxed and in good condition
   *New pistons ~8.8:1 CR
   *New bearings
   *Resused stock cast crank and rods, but put used ARP bolts
   *Aluminum water pump and housing
   *Edelbrock RPM manifold with 750 Speed Demon carb
   *Comp Cams XE274H cam kit with new springs, timing set, hydraulic lifters, pushrods
   *New mechanical fuel pump
   *Re-cored stock radiator with an additional core and higher densith of cooling tubes
Interior is in good condition, no rips, but not original front bucket seats
Column shift automatic
Stock 8 3/4 rear that has had the center section changed froma 741 to a 742 case with a powertrax unit
Piant is OK. It looks good from 20 feet, but there are a lot of flaws
There is a tiny bit of rust starting to bubble through on the passenger side lower portion of the fender, right near the door. Otherwise, the car appears to be rust free.
All new stock brakes (rotors, caliperss, drums as well as pads)
Electronic ignition conversion with orange box
It is a non A/C car.
It is in good running condition as well.
I am attaching a few pics as well. I will get some pics with the 440 installed tonight. I was curious what people thinks its value might be.  :dunno: Thanks in advance. I really am hoping not to have to sell it, but just in case I would like to get an idea. Just for information, I paid $8200 for the car about 2 and a half years ago and have since put $4000 into it between the motor, tranny, brakes, and stuff to keep it running.
1971 Dodge Challenger
2009 Dodge Challenger R/T, 6 speed manual
2009 Dodge Charger R/T w/ Road & Track Package
1995 Ford F-150
Re: 71 340 Challenger Value?
« Reply #1 on: November 03, 2006 - 02:05:08 PM »
A few interior pics
1995 Ford F-150
« Reply #2 on: November 03, 2006 - 02:05:57 PM »
A few other pics that might be helpful.
1995 Ford F-150
« Reply #3 on: November 03, 2006 - 10:02:10 PM »
Here are a couple of pictures of the nwe 440 installed with new Schumacher headers.
1995 Ford F-150
Offline Rev-It-Up
  • Global Moderator
  • Member Since 2/20/02
« Reply #4 on: November 04, 2006 - 07:29:12 AM »
I'll throw out a number to get the ball rolling...  I'll say, $15K to $17.5K.
Offline mmccarty
  • My other ride...
« Reply #5 on: November 04, 2006 - 09:42:10 AM »
 :iagree: My first thought was $15k or so.
« Reply #6 on: November 04, 2006 - 10:32:14 AM »
My initial thoughts were in the $15k-$20k range as well. But, you always think your own car is worth more I think. And, looking at eBay, and all the auctions, you start to think your car is worth a lot more than it really is. I really don't want to have to sell it, but if things don't work out, it will probably have to go.  :crying: :'(
1995 Ford F-150
