Author Topic: any difference in cams?  (Read 653 times)
Offline 73 challenger 440
« on: November 06, 2006 - 08:51:50 PM »
I wanted to get a set of gear drives, as I am replacing my camshaft.. I was told some cams come with a one hole or a 3 hole where the top timing gear would attach. what are the difference for??
Re: any difference in cams?
« Reply #1 on: November 06, 2006 - 11:27:51 PM »
3 bolt is used on more agressive cam profiles where the spring load is increased , personally wherever possible I order cams with 3 bolt
« Reply #2 on: November 07, 2006 - 09:04:18 PM »
if I have a 1 hole cam, if I decide to grab a 3 hole, would the only change I would have to make is to get a 3 hole timing gear? everything else is the same?
Offline JS27N0B
  • Member since Jan 28th 2003.
« Reply #3 on: November 07, 2006 - 09:16:32 PM »
Correct.  Hemis and 440 6paks came with 3 bolt cam gears but any B engine can use them providing there is a cam profile you like that is offered with the choice.
2013 Tige' RZR 343hp
« Reply #4 on: November 08, 2006 - 05:06:55 AM »
thanks for the information.
