Author Topic: IDing an unknown spe PurpleShaft?  (Read 846 times)
Offline GoodysGotaCuda
« on: November 08, 2006 - 12:36:42 AM »
I have, what i have been told, is a '.509 MP purpleshaft'.  I know nothing more on it, There are a couple cast numbers and such, is there any markings on it that give away what the specs would be? If not, just use a mic and check the lift? anyway to figure out the duration?
Thanks  :cheers:
1976 Dodge Warlock
Wheel & Tire Specs:Link
Re: IDing an unknown spe PurpleShaft?
« Reply #1 on: November 08, 2006 - 01:28:39 AM »
if you know it is a purple shaft mic the lift
« Reply #2 on: November 08, 2006 - 10:34:40 AM »
Mic a lobe? or stick it in the motor and see how much the lifter goes up? micing a lobe i got .408...which cant be right x 1.5 = .612  :eek4:
1976 Dodge Warlock
Offline tactransman
« Reply #3 on: November 08, 2006 - 04:20:22 PM »
Lobe measurement minus base circle X rocker ratio (1.5) = lift
Terry-tactransman
Union, Mo.
« Reply #4 on: November 08, 2006 - 04:42:54 PM »
How do i figure out the base circle? thanx
1976 Dodge Warlock
Offline tactransman
« Reply #5 on: November 08, 2006 - 04:48:49 PM »
measure it ( 90 degrees from the lobe)  straight across in the first pic on the left
« Last Edit: November 08, 2006 - 04:57:36 PM by tactransman »
Terry-tactransman
Union, Mo.
« Reply #6 on: November 08, 2006 - 05:16:03 PM »
So would the one on the left be the right spot to measure for the base circle? And the right would be the lobe measurement?  :clueless:
1976 Dodge Warlock
Offline tactransman
« Reply #7 on: November 08, 2006 - 06:22:06 PM »
Yes and Yes
Terry-tactransman
Union, Mo.
« Reply #8 on: November 09, 2006 - 02:04:43 AM »
ok well i either
A) cant totally read a caliper mic
or
B) cant totally read a caliper mic
Because i'm coming up with like .6xx lift  :faint: I'm getting, what i think is 1.684 total lobe height, and pictured...what i think is 1.261 (.5)
Is that whats pictured? or am i just totally  :screwy:
1976 Dodge Warlock
Offline tactransman
« Reply #9 on: November 09, 2006 - 07:05:17 AM »
Maybe it is not a .509 cam? :dunno:
Mopar Cam Specs:
Terry-tactransman
Union, Mo.
