Author Topic: input shaft on tranny too long?  (Read 1556 times)
Offline 1970hemicuda
« on: November 08, 2006 - 11:05:38 PM »
Anybody ever heard of the input shaft on a A-833 being too long to bolt up to a new 360 crate motor?  I'm hitting the crankshaft with 3/8" more to go to flush up the tranny with the bell housing.  Help!!
Offline 1 Wild R/T
Re: input shaft on tranny too long?
« Reply #1 on: November 08, 2006 - 11:14:35 PM »
Sounds like the crank wasn't drilled deep enough.. You have two choices, have the crank drilled deeper, or cut the input shaft off a little shorter...
« Reply #2 on: November 08, 2006 - 11:20:50 PM »
Yeah, my thought was to cut the input shaft, but I'd never heard of that being done.  Any tips?
« Reply #3 on: November 09, 2006 - 12:38:06 AM »
I would be more inclined to drill the hole in the crank
Offline 1 Wild R/T
« Reply #4 on: November 09, 2006 - 12:46:48 AM »
Acually cutting the input down has been done quite a bit, GM & Ford inputs only have about 1.25" bearing surface or their inputs, mopar has about  2" & a larger diameter for more surface area... :2cents:
But on the flip side, if you have access to a mag drill or can rent one the crank could be drilled with the crank in the engine & the engine in the car, you would likely need the replace the pilot bushing as it would act as a guide for the drill & be damaged, but it is doable..
« Last Edit: November 09, 2006 - 12:52:17 AM by 1 Wild R/T »
« Reply #5 on: November 09, 2006 - 01:30:01 PM »
Thanks guys ... gonna cut the input shaft ~
