Author Topic: Time for an oil change  (Read 3127 times)
Offline zerfetzen
  • 'Cuda, should'a, would'a...you lost.
« on: November 09, 2006 - 07:05:55 PM »
In everyday driving, we all know how often it's common practice to change the oil.  But my question is, how often should you change the oil in a car that's rarely driven?
Offline Challenger6pak
Re: Time for an oil change
« Reply #1 on: November 09, 2006 - 07:21:04 PM »
Good question. I would like to know the answer also.  We might need a chemist to let us know if and when oil breaks down when not in use.  I would guess the additives are the things to worry about breaking down.
« Reply #2 on: November 09, 2006 - 07:42:43 PM »
well I go with the old saying Oil is cheap & engines are not
 but I don`t do my often enough either
Offline BIGSHCLUNK
« Reply #3 on: November 09, 2006 - 07:49:48 PM »
I generally put on less than 1000 a year on any collector/muscle cars that I've owned. Right or wrong no more than once a year.  :dunno:
                                             [o o o o]
                                                  OO
                                                  OO
                                              [o o o o]
Offline Super Blue 72
    • Phil's Super Blue '72
« Reply #4 on: November 09, 2006 - 08:21:36 PM »
Ya have to change the oil?
Oh, geeeze.... :faint:   :roflsmiley:
Since I don't have mine registered it's easy to forget to change it.  I think I do it once every 2 years.  I know I should do it much more often!  :banghead:
I better get  :working:
71challengher
« Reply #5 on: November 09, 2006 - 08:26:56 PM »
I have mine changed twice a year , regardless of the mileage.
« Reply #6 on: November 09, 2006 - 09:04:26 PM »
probably the best is once / year in the fall when you store it for winter so the oil is clean while it sits over winter
 More often will not hurt
Offline GoodysGotaCuda
« Reply #7 on: November 09, 2006 - 10:29:30 PM »
When i daily drove mine, i changed it whenever i felt really. Oil is cheap...relatively. If i usually about 2000miles actually, if i found i was going racing or running it hard i changed it. Running 3.91s and having a heavy foot i was pretty hard on it.. :bigsmile:
1976 Dodge Warlock
Wheel & Tire Specs:Link
Offline pink panther
« Reply #8 on: November 10, 2006 - 08:11:52 AM »
Usually change mine once a year, question for me what is the best oil and viscoity to use in a built motor?  I heard something like 5W 30? Is royal purple worth the money?
Offline zerfetzen
« Reply #9 on: November 10, 2006 - 08:45:25 AM »
Hi Pink,
I found this article online and am posting it here (I hope, but doubt, the tables come out):
Part 1:
More Than You Ever Wanted to Know About Motor Oil
by Ed Hackett
(updated as of July 11th, 1999)
Date: Fri, 9 Jul 99 21:22:04 -0700
To: "H. Marc Lewis" <marcl@micapeak.com>
My "oil" article at http://www.micapeak.com/info/oiled.html is the latest version. I haven't had the time or desire to do any more with the article. It is as up to date as it's going to get. Regarding the age of the data -- you can now usually find current data on the oil company's Web pages.
Choosing the best motor oil is a topic that comes up frequently in discussions between motorheads, whether they are talking about motorcycles or cars. The following article is intended to help you make a choice based on more than the advertising hype.
Oil companies provide data on their oils most often referred to as "typical inspection data". This is an average of the actual physical and a few common chemical properties of their oils. This information is available to the public through their distributors or by writing or calling the company directly. I have compiled a list of the most popular, premium oils so that a ready comparison can be made. If your favorite oil is not on the list get the data from the distributor and use what I have as a data base.
This article is going to look at six of the most important properties of a motor oil readily availiable to the public: viscosity, viscosity index (VI), flash point, pour point, % sulfated ash, and % zinc.
Viscosity is a measure of the "flowability" of an oil. More specifically, it is the property of an oil to develop and maintain a certain amount of sheering stress dependent on flow and then to offer continued resistance to flow. Thicker oils generally have a higher viscosity, and thinner oils a lower viscosity. This is the most important property for an engine. An oil with too low a viscosity can shear and loose film strength at high temperatures. An oil with too high a viscosity may not pump to the proper parts at low temperatures and the film may tear at high rpm.
The weights given on oils are arbitrary numbers assigned by the S.A.E. (Society of Automotive Engineers). These numbers correspond to "real" viscosity, as measured by several accepted techniques. These measurements are taken at specific temperatures. Oils that fall into a certain range are designated 5, 10, 20, 30, 40, 50 by the S.A.E. The W means the oil meets specifications for viscosity at various low temperatures depending on weight, and is therefore suitable for Winter use. 5W is tested at -25C, 10W at -20C, 15W at -15C, and 20W at -10C.
The following chart shows the relationship of "real" viscosity to their S.A.E. assigned numbers. The relationship of gear oils to engine oils is also shown.
_______________________________________________________________
|      SAE Gear Viscosity Number                              |
|  ________________________________________________________   |
|  |75W |80W  |85W|    90        |        140             |   |
|  |____|_____|___|______________|________________________|   |
|     SAE Crank Case Viscosity Number                         |
|  |10| 20  | 30 | 40  |  50  |                               |
|  |__|_____|____|_____|______|                               |
2  4  6  8  10 12 14 16 18 20 22 24 26 28 30 32 34 36 38 40 42
viscosity cSt @ 100 degrees C
Offline zerfetzen
« Reply #10 on: November 10, 2006 - 08:45:58 AM »
Part 2:
Multi viscosity oils work like this: Polymers are added to a light base (5W, 10W, 20W), which prevent the oil from thinning as much as it warms up. At cold temperatures the polymers are coiled up and allow the oil to flow as their low numbers indicate. As the oil warms up the polymers begin to unwind into long chains that prevent the oil from thinning as much as it normally would. The result is that at 100 degrees C the oil has thinned only as much as the higher viscosity number indicates. Another way of looking at multi-vis oils is to think of a 20W-50 as a 20 weight oil that will not thin more than a 50 weight would when hot.
Multi viscosity oils are one of the great improvements in oils, but they should be chosen wisely. Always use a multi grade with the narrowest span of viscosity that is appropriate for the temperatures you are going to encounter. In the winter base your decision on the lowest temperature you will encounter, in the summer, the highest temperature you expect. The polymers can shear and burn forming deposits that can cause ring sticking and other problems. 10W-40 and 5W-30 require a lot of polymers (synthetics excluded) to achieve that range. This has caused problems in diesel engines, but fewer polymers are better for all engines. The wide viscosity range oils, in general, are more prone to viscosity and thermal breakdown due to the high polymer content. It is the oil that lubricates, not the additives. Oils that can do their job with the fewest additives are the best.
Very few manufacturers recommend 10W-40 any more, and some threaten to void warranties if it is used. It was not included in this article for that reason. 20W-50 is the same 30 point spread, but because it starts with a heavier base it requires less viscosity index improvers (polymers) to do the job. AMSOIL can formulate their 10W-30 and 15W-40 with no viscosity index improvers but uses some in the 10W-40 and 5W-30. Other multi-grade synthetics may not use VI improvers either. The full literature available from the oil company should include this information. Follow your manufacturer's recommendations as to which weights are appropriate for your vehicle.
Viscosity Index is an empirical number indicating the rate of change in viscosity of an oil within a given temperature range. Higher numbers indicate a low change, lower numbers indicate a relatively large change. The higher the number of the Viscosity Index the better. This is one major property of an oil that keeps your bearings happy. These numbers can only be compared within a viscosity range. It is not an indication of how well the oil resists thermal breakdown.
Flash point is the temperature at which an oil gives off vapors that can be ignited with a flame held over the oil. The lower the flash point the greater tendency for the oil to suffer vaporization loss at high temperatures and to burn off on hot cylinder walls and pistons. The flash point can be an indicator of the quality of the base stock used. The higher the flash point the better. 400 F is the minimum to prevent possible high consumption. Flash point is in degrees F.
Pour point is 5 degrees F above the point at which a chilled oil shows no movement at the surface for 5 seconds when inclined. This measurement is especially important for oils used in the winter. A borderline pumping temperature is given by some manufacturers. This is the temperature at which the oil will pump and maintain adequate oil pressure. This was not given by a lot of the manufacturers, but seems to be about 20 degrees F above the pour point. The lower the pour point the better. Pour point is in degrees F.
Offline zerfetzen
« Reply #11 on: November 10, 2006 - 08:46:29 AM »
Part 3:
% sulfated ash is how much solid material is left when the oil is reacted with sulfuric acid and burned. This is used to quantify the amount of metallic antiwear and detergent additives in the oil. Zinc dithiophosphate is a common detergent and antiwear additive that is reflected in this test.
% zinc is the amount of zinc used as an extreme pressure, anti- wear additive. The zinc is only used when there is actual metal to metal contact in the engine. Hopefully the oil will do its job and this will rarely occur, but if it does, the zinc compounds react with the metal to prevent scuffing and wear. A level of .11% is enough to protect an automobile engine for the extended oil drain interval, under normal use. Those of you with high reving, air cooled motorcycles or turbo charged cars or bikes might want to look at the oils with the higher zinc content. More doesn't give you better protection, it gives you longer protection if the rate of metal to metal contact is abnormally high.
The Data: (Note: this data is mostly from 1991 and is for SG rated oils. Some of the data is current, and I am working on collecting the most recent data. I have found over the years that the "better" oils remain the "better" oils. It is still valid as a place to start in your own search. The formulation of oils is constantly being updated and subject to change by the manufacturer at any time. The best thing to do is collect data on the oils you are interested in directly from the oil company.)
[An * after the oil name indicates current SH rated version.]
Listed alphabetically. Empty cells indicate the data was unavailable.
Brand    VI    Flash    Pour    %
ash    %
zinc
20W-50
AMSOIL*    151    507    -45
AMSOIL Series 2000*    155    474    -47
Castrol GTX*    122    440    -15    .85    .12
Castrol Syntec Blend*    135    440    -17         .105
Chevron Supreme*    140    428    -17    <1
Exxon High Performance    119    419    -13    .70    .11
Havoline Formula 3    125    465    -30    1.0
Kendall GT-1    129    390    -25    1.0    .16
Pennzoil GT Perf.    120    460    -10    .9
Quaker State Perf.*    121    440    -20
Quaker State Motorcycle 140    440    -25
Red Line    150    503    -49
Shell Fire and Ice*    126    450    -10    .9    .12
Shell Truck Guard*    130    450    -15    1.0    .12
Spectro Golden 4    174    440    -35         .15
Spectro Golden M.G.    174    440    -35         .13
Ultra Chem    190    455    -34
Unocal    121    432    -11    .74    .12
Valvoline All Climate    125    430    -10    1.0    .11
Valvoline Turbo    140    440    -10    .99    .13
Valvoline Race    140    425    -10    1.2    .20
Valvoline DuraBlend    126    455    -17    <1.5    .125
Valvoline Synthetic    146    465    -40    <1.5    .12
15W-50
Mobil 1    170    470    -55
Mystic JT8    144    420    -20    1.7    .15
Red Line    152    503    -49
5W-50
Castrol Syntec*    175    465    <-54         .102
Chevron Supreme*    175    460    -38    1.45
Quaker State Synquest*    175    460    -50
Pennzoil Performax    176         -69
5W-40
Havoline    170    450    -40    1.4
15W-40
AMSOIL*    165    462    -49
Castrol    134    415    -15    1.3    .14
Chevron Delo 400*    134    424    -38    <1
Exxon XD3         417    -11    .9    .14
Exxon XD3 Extra    135    399    -11    .95    .13
Kendall GT-1    135    410    -25    1.0    .16
Mystic JT8    142    440    -20    1.7    .15
Quaker State*    129    420    -25
Quaker State HDX*    146    440    -30    .97
Quaker State HDX Plus*    148    420    -25    1.37
Red Line    149    495    -40
Shell Rotella w/XLA*    146    414    -32    1.0    .12
Valvoline All Fleet    140         -10    1.0    .15
Valvoline DuraBlend    137    450    -17    <1.5    .125
Valvoline Turbo    140    420    -10    .99    .13
10W-30
AMSOIL*    171    464    -54
Castrol GTX*    143    415    -32    1.07    .12
Castrol Syntec Blend*    138    415    -33         .105
Castrol Syntec*    157    455    <-54         .102
Chevron Supreme*    150    419    -27    <1
Exxon Superflo Hi Perf    135    392    -22    .70    .11
Exxon Superflo Supreme    133    400    -31    .85    .13
Havoline Formula 3    139    430    -30    1.0
Kendall GT-1    139    390    -25    1.0    .16
Mobil 1    160    450    -65
Pennzoil PLZ Turbo    140    410    -27    1.0
Quaker State*    140    410    -30    .9
Quaker State 4x4*    135    430    -35
Red Line    139    475    -40
Shell Fire and Ice*    155    410    -35    .9    .12
Shell Rotella w/XLA*    155    405    -37    1.0    .12
Shell Truck Guard*    155    405    -35    1.0    .12
Spectro Golden M.G.    175    405    -40
Unocal Super    153    428    -33    .92    .12
Valvoline All Climate    130    410    -26    1.0    .11
Valvoline Turbo    135    410    -26    .99    .13
Valvoline Race    130    410    -26    1.2    .20
Valvoline DuraBlend    142    440    -27    <1.5    .125
Valvoline Synthetic    140    450    -40    <1.5    .12
5W-30
AMSOIL*    186    478    -67
Castrol GTX*    160    410    -35    1.35    .12
Chevron Supreme*    167    410    -38    <1
Chevron Supreme Synt.*    169    468    -49
Exxon Superflow HP    148    392    -22    .70    .11
Havoline Formula 3    158    420    -40    1.0
Mobil 1    165    445    -65
Mystic JT8    161    390    -25    .95    .1
Quaker State*    155    405    -35
Quaker State Synquest*    168    450    -58
Red Line    151    455    -49
Shell Fire and Ice*    167    405    -35    .9    .12
Unocal    151    414    -33    .81    .12
Valvoline All Climate    135    405    -40    1.0    .11
Valvoline Turbo    158    405    -40    .99    .13
Valvoline DuraBlend    162    415    -38    <1.5    .125
Valvoline Synthetic    160    435    -40    <1.5    .12
Note: * indicates current SH rated oil
Offline zerfetzen
« Reply #12 on: November 10, 2006 - 08:46:47 AM »
Part 4 (Final):
All of the oils above meet current SG/CD ratings and all vehicle manufacture's warranty requirements in the proper viscosity. All are "good enough", but those with the better numbers are icing on the cake.
The synthetics offer the only truly significant differences, due to their superior high temperature oxidation resistance, high film strength, very low tendency to form deposits, stable viscosity base, and low temperature flow characteristics. Synthetics are superior lubricants compared to traditional petroleum oils. You will have to decide if their high cost is justified in your application.
The extended oil drain intervals given by the vehicle manufacturers (typically 7500 miles) and synthetic oil companies(up to 25,000 miles) are for what is called normal service. Normal service is defined as the engine at normal operating temperature, at highway speeds, and in a dust free environment. Stop and go, city driving, trips of less than 10 miles, or extreme heat or cold puts the oil change interval into the severe service category, which is 3000 miles for most vehicles. Synthetics can be run two to three times the mileage of petroleum oils with no problems. They do not react to combustion and combustion by-products to the extent that the dead dinosaur juice does. The longer drain intervals possible help take the bite out of the higher cost of the synthetics. If your car or bike is still under warranty you will have to stick to the recommended drain intervals. These are set for petroleum oils and the manufacturers make no official allowance for the use of synthetics. Some oil companies, AMSOIL being an example, offer their own engine warranties. If the oils are used in compliance with the company's recommendations (including extended drain intervals) and a problem is caused by the engine oil, the company will pay for the repairs. Check with the company for specifics of any warranties offered.
Oil additives should not be used. The oil companies have gone to great lengths to develop an additive package that meets the vehicle's requirements. Some of these additives are synergistic, that is the effect of two additives together is greater than the effect of each acting separately. If you add anything to the oil you may upset this balance and prevent the oil from performing to specification.
The numbers above are not, by any means, all there is to determining what makes a top quality oil. The exact base stock used, the type, quality, and quantity of additives used are very important. The given data combined with the manufacturer's claims, your personal experience, and the reputation of the oil among others who use it should help you make an informed choice.
Offline zerfetzen
« Reply #13 on: November 10, 2006 - 08:47:55 AM »
All of that said, my motor has Valvoline 20/50 in it.  This was the way I received it, and think it is a good choice.
Offline Oldschool
  • Member Since 9-05-06
« Reply #14 on: November 10, 2006 - 02:46:40 PM »
Great info Zerf...........    :2thumbs:
(Anybody get the Cliff Notes for me)?     :smilielol:   :roflsmiley:   :bigsmile:   :cooldancing:
Ken  --  In Georgia
