Author Topic: B&M Megashifter  (Read 5551 times)
Offline zerfetzen
  • 'Cuda, should'a, would'a...you lost.
B&M Megashifter
« on: November 11, 2006 - 07:54:52 PM »
How do you use it?  No really, you read that right...
I took the barracuda for a short ride today to stretch its legs, and had a blast, except...
I have a Holley electric fuel pump, so I was told I have to start it in neutral.  Of course you can't read what gear you're in, so you pull it down to low 1, then slap it forward like a slapstick, and when it doesn't go any farther, it must be in neutral.  No prob, all good to go.  So I start it, back it out, drop it in low 1, and away I go.  As needed, I slap it forward into higher gears.
But when I came to a stoplight, I pulled the ratchet (whatever it's called), and dropped it back into low 1.  I started driving, and when I slapped it, it didn't shift into 2nd.  I'm sure it's driver error.  Am I supposed to do something different, like bring it into neutral, then all the way down to low 1 before I can slap it forward?   :dunno:  What's the trick to correctly using a B&M Megashifter?
Offline tactransman
Re: B&M Megashifter
« Reply #1 on: November 11, 2006 - 08:03:21 PM »
That is why I do not like ratchet shifters , I like the the shifter handle to change positions when you shift it. It is almost like the brain "registers" it better that you shifted. :burnout: :burnout: :burnout:
        1        2        3
        :bigsmile:
Terry-tactransman
Union, Mo.
Re: B&M Megashifter
« Reply #2 on: November 12, 2006 - 04:14:02 AM »
the Factory Slapstick is far better , you may need to tweak the adjustment to get the shift to line up correctly
Offline tactransman
Re: B&M Megashifter
« Reply #3 on: November 12, 2006 - 06:13:48 AM »
This is the only aftermarket shifter I like. It is not a ratchet shifter.
BMM-80706
$164.95
Automatic Shifter, Pro Stick, Chevy/Mopar/Ford/Lincoln/Mercury, Each
The competition shifter that fits almost any transmission.
These B&M Pro Stick automatic shifters have every feature you need in a competition shifter: Compact size, spring-loaded gate action for consistent shifts, one-hand reverse lockout, and a feature the competitors don't have--they can fit more than one transmission. With B&M's optional gate plates, the Pro Sticks will fit most 2, 3, and 4-speed automatics. Now when you change transmissions, you don't have to change shifters
 :thumbsup:
Terry-tactransman
Union, Mo.
Offline zerfetzen
Re: B&M Megashifter
« Reply #4 on: November 12, 2006 - 09:29:20 AM »
Thanks for the feedback, I'm with all of you, and will change this back.  I've seen the original setup very briefly, but haven't done this before.  Is there anything tricky I should be aware of?  It seems to me it should be as simple as unscrewing the plate that holds it on, releasing a rod IIRC, and replacing it with the new one?  Or should I take out the whole console to get to it?  Thanks, just looking ahead.  Cheers.
Re: B&M Megashifter
« Reply #5 on: November 12, 2006 - 11:35:45 AM »
you have to remove the console /4 screws/ ususally just cleaning & lubing the shifter will get it working correctly again , sometimes the spring will break & will require a replacement
Offline Super Blue 72
    • Phil's Super Blue '72
Re: B&M Megashifter
« Reply #6 on: November 12, 2006 - 12:06:38 PM »
Sorry, call me goofy  :crazy: ,
but one of the things I like about the factory Slap Stik shifter is that the gear indicator needle changes color depending what gear you in.
Also, it does work pretty cool!  :thumbsup:
Offline tactransman
Re: B&M Megashifter
« Reply #7 on: November 12, 2006 - 12:18:16 PM »
:iagree:  We are both goofy. :crazy: :crazy:
Terry-tactransman
Union, Mo.
Re: B&M Megashifter
« Reply #8 on: November 12, 2006 - 12:39:32 PM »
 :cheers:  :drunk:
Offline Jacksboys
  • Here Since 08/28/06 GEORGIA
Re: B&M Megashifter
« Reply #9 on: November 12, 2006 - 12:43:43 PM »
:iagree: No chance of making a mistake.
Re: B&M Megashifter
« Reply #10 on: November 12, 2006 - 12:44:19 PM »
I guess that makes 3 goofy people , I have not found any aftermarket shifter that is as reliable & simple to operate as the factory Slapstick , not that I have ever owned one being a 4 spd guy
Re: B&M Megashifter
« Reply #11 on: November 12, 2006 - 12:51:21 PM »
Another fun factory shifter (Close your eyes of you don't like Pontiacs!) is from the Trans Ams with the WS6 handling package.  Other cars may have had something similar but I don't know.  :dunno:
The shifter looked like a regular Trans Am shifter but on certain ones when you drop it in 1st and push it to the right about 1/2", the shifter would only move up one gear at a time, like a Slap Stik but you didn't have to push the shifter button to bring it back to neutral.
Ok, back to Mopars....
Offline Jacksboys
Re: B&M Megashifter
« Reply #12 on: November 12, 2006 - 01:02:33 PM »
Yeah, I am a little goofy.  Many of the people I work with think I am goofy because I like Mopar.
Re: B&M Megashifter
« Reply #13 on: November 12, 2006 - 01:11:17 PM »
Nah, they're justy jealous!  :smilielol:  It's a good goofy, though.
It's that, "If you can't beat 'em, call them goofy" mentality.   :crazy:
Offline Plum6Pak
  • Plum6Pak
Re: B&M Megashifter
« Reply #14 on: November 12, 2006 - 01:55:05 PM »
We're all in the same  :crazy: goofy batch, I really like the slapstick shifter. Hit it hard from first to second, let up a bit off of the lever slam it into the next one. Simple and sweet.
