Author Topic: Best all-around gears ???  (Read 4642 times)
Offline Madmax440
« on: November 12, 2006 - 11:31:09 AM »
I currently have Chrysler 8.75, Casting 489 1.875" Diameter pinion Gears from Richmond. These are hell when I am driving on the highway. It feels like it needs another gear once I get up around 55 mph, I go through the lower gears in no time. What would be a good all-around gear to use and would this be the only thing needing changed ???
Offline GoodysGotaCuda
Re: Best all-around gears ???
« Reply #1 on: November 12, 2006 - 11:32:55 AM »
What ratio do you have? i would say 3.23/3.55 is a decent all around gear. New ring/pinion/speedo gear is what you would need. Ultimate setup would be an overdrive (but $$$)
1976 Dodge Warlock
Wheel & Tire Specs:Link
« Reply #2 on: November 12, 2006 - 11:39:38 AM »
you May need a brg & seal kit to install different gears into your carrier , everyone will have a different opinion of what is the best gear depending what you want the car for , personally I like taller gears , 2.7 or 2.9 for highway , 3.23 is good midrange gear , 3.55 are good for both highway & city depending on tire size , anything over 3.55 will limit highway use for sure
Offline Jacksboys
  • Here Since 08/28/06 GEORGIA
« Reply #3 on: November 12, 2006 - 12:22:35 PM »
I have a 904, 3.23 gears, and 28 inch rear tires and the engine is turning 3000 rpm at 80 mph.  Like Chryco said "everyone will have a different opinion", but I like my setup very much.   Just my  :2cents:
« Reply #4 on: November 12, 2006 - 01:03:33 PM »
What RPM's are you doing on the hiway? I have the 8 3/4 rear, 489 casting, and 3:23 gears. At 60 MPH, I do about 2600 RPM. Not too bad. A shift kit in my tranny allows me to delay my shifting too.  :burnout:
Offline Jacksboys
« Reply #5 on: November 12, 2006 - 01:05:17 PM »
I forgot to mention that my tranny also like to shift fast.  You may need to adjust the shift linkage for my setup.
Alaskan_TA
« Reply #6 on: November 12, 2006 - 01:09:03 PM »
For the cars I have driven a lot of miles on, I pefer a 3.23 gear with the automatic and a 3.55 with the four speed.
Barry
« Reply #7 on: November 12, 2006 - 01:31:01 PM »
 Adjust the Kickdown linkage , make sure it is allthe way back with the throttle wide open
Offline torredcuda
  • Epping NH joined 11/23/03
« Reply #8 on: November 12, 2006 - 01:37:03 PM »
I have 3.91`s in my `72 but at 65-75 it`s spinning 3500-3800rpm which is buzzing but my 340 dosen`t seem to mind for short highway jaunts under 45 minutes.I plan on using 3.23`s for my road runner for a nice criuser for longer distances.
Jeff
72 Barracuda 340/4spd  Torred
04 Ram 2500 5.7 Hemi
Offline Plum6Pak
  • Plum6Pak
« Reply #9 on: November 12, 2006 - 01:50:06 PM »
Hey Madmax440, if you're running a 440 and have the torque, I'd stick with 3:23's, if you are running small block, go for the 3:55's. Just my opinion but the higher torque engines do quite well with a bit taller gears. I was planning on 3:55's in my 70 B body that's running a big block but since I've got it running and tried it out with a sure grip 3:23 in it I am sticking with the 3:23's for now. I'd rather do that then try to make the tires stick with lower gears. Just my thoughts on this. Let us know what you end up doing and how it works.
Offline Jacksboys
« Reply #10 on: November 12, 2006 - 07:35:00 PM »
Thanks Chryco, I will have to adjust it the next time I am under the hood.
« Reply #11 on: November 12, 2006 - 07:45:13 PM »
actually imo, there should be a hair of play at WOT. you dont want to have the trans bottom out and limit you from getting true wot  :2cents:
1976 Dodge Warlock
Offline Carlwalski
« Reply #12 on: November 12, 2006 - 09:29:40 PM »
All round would be street, so 3.23 definitely.  :thumbsup:
No such thing as a 1/4 mile track all round gear, you only need it for one thing.
1970 Dodge Challenger R/T
White, License Plate, 0A-5599
« Reply #13 on: November 12, 2006 - 10:09:18 PM »
I run 410's in the 440 auto and 355 in the 440 stick. The 410 challenger I just stay off the interstate and use the car for fun, Cruising is 3200. Don't know what speed it is. Havent done the speedo yet. My car hooks good with a 3k stall and the 410's.
Offline 1 Wild R/T
« Reply #14 on: November 12, 2006 - 11:09:39 PM »
Depends on if your hardcore...Back in the eighties I drove a 440-6 Challenger R/T with a 4.10 Dana from central California (Modesto) to San Diego, round trip about 1,000+ miles aveage speed 60mph 28" tire engine spinning 31-3200 rpms...That said I wouldn't do it again.. :smilielol: If you are doing allot of around town stop light to stop light with a little highway action I'd run 3.55's if your on the freeway allot 3.23's are a decent gear or maybe 2.94's...
