Author Topic: Best all-around gears ???  (Read 4644 times)
Re: Best all-around gears ???
« Reply #30 on: November 15, 2006 - 01:54:35 PM »
Can you figure out exactly which speedo gear is needed for a 3.55 gear with 28" tall tires ?
That is what it proports to do.  Will have to know a tire size that is 28" tall 1st.
varialbes are tire size\aspect\diameter\gear & calculations are made, email on the way
« Last Edit: November 15, 2006 - 01:57:27 PM by bullitt99 »
« Reply #31 on: November 15, 2006 - 02:20:12 PM »
275/60 R15
« Reply #32 on: November 15, 2006 - 02:48:36 PM »
275/60 R15
TYRE SIZE         275   60   15
REAR END RATIO         3.55
TYRE DIAMETER =       27.99
TYRE WIDTH =       10.83
CIRCUMFERENCE =       87.94
SPEEDO PINION GEAR TEETH =       33.25
   Did you get the email?
« Reply #33 on: November 15, 2006 - 03:26:13 PM »
Thanks  :2thumbs:
Offline FY1Cuda
« Reply #34 on: November 29, 2006 - 02:00:57 AM »
My Cuda is running 3.91s and the car winds hard on the freeway.  65mph @ 3500rpm.  Last time I was getting on the freeway I tried to shift into 5th since I am used to my daily driver, needless to say, I shifted from 4th back into 4th.   :burnout:
« Reply #35 on: November 29, 2006 - 02:06:22 AM »
I got the Email But I couldn`t open the attachment
 you could PM me here with it
« Reply #36 on: November 29, 2006 - 07:01:21 AM »
Here are the links to these spread sheets, Cut & Paste to Excel to keep http://www.moparts.com/Tech/tech/img/AUTOMATICchart.xls
http://www.moparts.com/Tech/tech/img/4SPEEDchart.xls
Offline vinb
« Reply #37 on: November 29, 2006 - 07:36:13 PM »
I got a 275/60/15 tire which is 28.01"/ 89" roll out with a 3.55 gear and a 33 yellow tooth gear. Auto transmission , perfect in my 3600* Cuda...
Offline crcarch
  • Happiness is having the time and the money!
  • "No, it's not a Charger!"
    • A little history and restoration pics on Cardomain
« Reply #38 on: December 05, 2006 - 07:53:14 AM »
00/===\00 73 Challenger 440-4V/AT  8/--+--\8 09 Ram 1500  0o\==/o0 05 Crossfire Roadster OO(#####SRT)OO 10 Challenger
