Author Topic: 440 engine! !side item Starter stuck..!!!11/26 Not anymore, Now Videos  (Read 7657 times)
Offline 422STROKER
  • Member Since 6/3/06
Re: 440 engine question!!side item Starter stuck..!!!
« Reply #15 on: November 19, 2006 - 05:47:57 PM »
Loosen header and drivers side engine mount take a block of wood put on oil rail slowly jack up should have enough space to remove starter.
Tom
Tom
Offline DAYLEY/CHALLENGER
« Reply #16 on: November 19, 2006 - 06:15:43 PM »
I will try and post some pics.......The starter cavity is so close that it won't even slide forward enough to clear the bendix gear from the  bell housing.......The pics are not very good but here they are anyway.
Dave or David
Offline bb71challenger
« Reply #17 on: November 19, 2006 - 06:19:33 PM »
The tight clearance is probably the reason it does not work. I had a starter burn up due to header heat. One extra reason to get a ministarter  :bigsmile: Hope it works out for you. you definitely need to get the headers off to extract that starter  :eek4:
*Brett*
Offline RUSTY Cuda
  • One big step foward!
« Reply #18 on: November 19, 2006 - 07:57:17 PM »
WOW thats tight! kinda glad I got a small block now, good luck! Rich.
Offline 422STROKER
« Reply #19 on: November 20, 2006 - 02:14:58 PM »
That is tight maybe you need new headers while you are at it. LOL  I may have a Sawzall you can borrow!
Tom
I had cheap Hedmans and they fit well under 100 dollars
Tom
« Reply #20 on: November 20, 2006 - 02:58:46 PM »
There is only one painful solution. You have to remove the bolts from both ends of your header. I've been there, done that.  :pullinghair: Once the bolts are removed, you can pull the header forward, and tilt the header downward on the collector side, and the starter will clunk out onto the ground. Be ready for the anti-freeze to gush out when you remove the header bolts.  :22yikes: You will have to put some thread sealant on them when you put them back in. Like I said, I know your pain, but it can be done... eventually.  :grinyes:
« Last Edit: November 20, 2006 - 03:02:14 PM by MEKrunner »
« Reply #21 on: November 20, 2006 - 05:54:18 PM »
How about another chapter..........I removed all the nuts from the header bolts..All the bolts stayed in the block.  The header will not pull away from the block enough to clear the bolts because the steering box is in the way........ There are 6 or 8 bolts (I'm not looking right now) and I thought about double nutting the bolts to remove them but there is only room for one nut and washer with the header in place.           More opportunities!!!!!!!!!!!!!!1
Dave or David
« Reply #22 on: November 20, 2006 - 05:58:17 PM »
When I had some stubborn header studs that would not unbolt I just took some visegrips to them. There should be a change from standard thread to fine thread and a "hump" or bare spot between the two threads that you can get a good bite with the pliers. Might ruin the studs but sounds like you dont want them there anyway. Good luck!
*Brett*
« Reply #23 on: November 21, 2006 - 10:24:17 PM »
undo the left engine mount bolt put a board under the oil pan & raise the engine , you may need to remove both engine mount bolts
« Reply #24 on: November 22, 2006 - 10:35:28 AM »
How much can I jack the engine before I have to do something to the tranny moungings?
Dave or David
Offline RUSTY Cuda
« Reply #25 on: November 22, 2006 - 12:02:54 PM »
I just loosened the 2 tranny mount bolts to be safe, it went up about 4' with the one side loose!  Rich.
Corection, that was 4"  I'm sure you guys figgered it was a fat finger typo! Sorry! Rich.
« Last Edit: November 23, 2006 - 05:28:07 PM by RUSTY Cuda »
Offline ShelbyDogg
« Reply #26 on: November 23, 2006 - 02:26:22 PM »
You need to get those studs out of there with a vice-grips like a user said, Have the car jacked up in the front with tall jack stands, then tilt the whole header downward at the collector. The starter will slide out once turned the right direction.    If you HAVE TO,  put on the nut still flush with the troubled studs, then hit it with a mig welder and weld the nut to the stud, to get it out.
« Reply #27 on: November 23, 2006 - 09:15:42 PM »
if the studs are not stripped I would leave them in place , they seal the antifreeze better then the header bolts will
« Last Edit: November 23, 2006 - 09:39:19 PM by Chryco Psycho »
Offline ShelbyDogg
« Reply #28 on: November 23, 2006 - 09:35:52 PM »
Chryco is right on about that. Use the studs if headers can be slid over them to hold the gasket and header aligned while starting the bolts.
I remembered that AutoZone has a loan-a-tool of a nice set of stud extractors that work very well. You slip it over the sticking out stud, then put a ratchet on the end.  They work very well on broken off studs too.
« Reply #29 on: November 24, 2006 - 04:37:10 PM »
Ok folks....another chapter...........I removed the engine mount bolts.  Put a piece of wood on the oil pan rail and jacked..........The engine came up enough for me to realize this might just work.  Since I already had the starter loose and the header loose it wasn't long before I was high enough to remove the header and the starter fell out too.  Our Auto-Zone had 2 in stock.   Swapped out the core charge and brought it home....Will probably put it on Sunday. While I got the header off, I may as well clean it up and heat paint too..  Some pics attached..........Thanks to all for the help.    AND  I took a pic on the engine number......Anyone know when this engine may have been made? I don't know how to relate these numbers.   Thanks again,  David :working: :bigsmile:
I see where I said AutoZone......I meant to say Advance Auto.......... :screwy:
« Last Edit: November 24, 2006 - 06:44:52 PM by DAYLEY/CHALLENGER »
Dave or David
