Author Topic: 440 engine! !side item Starter stuck..!!!11/26 Not anymore, Now Videos  (Read 7650 times)
Offline bb71challenger
Re: 440 engine question!!side item Starter stuck..!!!
« Reply #30 on: November 24, 2006 - 05:14:12 PM »
Glad you got it off. Your engine has the cast in support ribs so it was made from 68 on. I bought a starter from autozone too and had to do the whole thing over about 2 months later because it went out. I hope you have better luck with yours.
*Brett*
Offline 422STROKER
  • Member Since 6/3/06
« Reply #31 on: November 24, 2006 - 05:35:58 PM »
 :working:     :2thumbs:
Tom :clapping:
Tom
Offline ShelbyDogg
« Reply #32 on: November 24, 2006 - 07:49:15 PM »
You should have got the smaller High torque starter for a little more money. Just ask for a later model Ram truck with a 5.2 or 5.9. The car will start faster without the anoying whinning noise.
The engine cast date is on the block, try looking on the other side.
Offline DAYLEY/CHALLENGER
Re: 440 engine question!!side item Starter stuck..!!!11/26 Not anymore
« Reply #33 on: November 26, 2006 - 05:47:22 PM »
 I forget what chapter we are on now.  Put the new starter on along with the header........Had to work them both in combination at same time to install.......Anyway , got all hooked up and it started.........after 1 1/2 years.  I think I must have swapped a couple of plug wires how it sounds but.............. :working:..............Ok I tried to attach a short video but it was too large..........It has the sounds of the engine.  I will post the link to my website for it when my son updates that.  I hope it will be tonight............Later, David
PS   I looked up the firing order  1 8 4 3 6 5 7 2.. and going from the engine piston layout........Right side being 1357 and the left being 2468. Standing in front on the engine, As viewed from the rear to front.    With the rotation of the dist  being counterclockwise.
Correct or not????????????????  Thanks ,David
Dave or David
« Reply #34 on: November 26, 2006 - 06:05:57 PM »
    2-4-6-8
< front grille
   1-3-5-7
firing order is 1-8-4-3-6-5-7-2
 rotation is counterclockwise on a big block
« Reply #35 on: November 26, 2006 - 06:13:54 PM »
Based on that layout..........I got then all wrong.............  Clarify that the #1 plug is on the drivers side and the first one at the radiator.  Thanks, David
Dave or David
Offline 422STROKER
« Reply #36 on: November 26, 2006 - 06:27:53 PM »
Yup!
Tom
I'm surprised it ran!
Tom
« Reply #37 on: November 26, 2006 - 06:40:05 PM »
NO doubt
yup #1 is drivers front
« Reply #38 on: November 26, 2006 - 06:43:43 PM »
My son is at this moment updating the website...........http://big-dog.us/challenger/             Click on the video section.  There is one on now and 3 or 4 more to be put on tonight if I can get this PC to act right.
He will finish the update tomorrow night............
« Last Edit: November 26, 2006 - 08:43:41 PM by DAYLEY/CHALLENGER »
Dave or David
Offline ShelbyDogg
« Reply #39 on: November 27, 2006 - 09:00:59 AM »
David,
Do not start that car again till you get that firing order corrected.
That video plays a sound of an engine with a misfire or bad intake valve.
Pull all of the plugs, put a timing light on number 1 wire, lay all of the plugs with the wires plugged onto them on the valve covers, then crank and set your timing to about 8 degrees advance.  Lock down the distributor, then start checking the firing order while installing the plugs.
Re: 440 engine question!!side item Starter stuck..!!!11/26 Not anymore/ videos
« Reply #40 on: December 01, 2006 - 12:25:11 PM »
http://www.big-dog.us/challenger/
We have a video section now.  Don't pay too much attention to the Start it up one. That was when It was rough.  Look at the second video.   And I will put more on this weekend.........Not bad after setting 1 1/2  years.
OK.........Now have 6 videos loaded.   The first 4 are rough.  I did some timing and new plugs(should have before) and the engine now sounds a lot better.  There is still some adjusting to be done on the 750 carb.  Too rich.  Floundered in the driveway this morning and when it caught I layed down some rubber.  Let me know how it sounds now.  David
« Last Edit: December 03, 2006 - 08:57:07 PM by DAYLEY/CHALLENGER »
Dave or David
Re: 440 engine! !side item Starter stuck..!!!11/26 Not anymore, Now Videos
« Reply #41 on: December 04, 2006 - 07:54:40 AM »
Had to repost to move to the top of the thread.   Check out post #40....
Dave or David
Offline 4Cruizn
  • HEMI FISH
« Reply #42 on: December 04, 2006 - 08:27:40 AM »
WOW that was alot of work to remove a starter!!  I would of been  :pullinghair:  :banghead:  Glad it's worked out for you!   :bigsmile:
« Reply #43 on: December 04, 2006 - 04:42:28 PM »
David, Sounds like home,  :burnout: GREAT To See & Hear your progress  :2thumbs: . I had some of the same issues after mine had sat for 15 years. Could not believe what an improvement new wires & plugs could make. Then added a new Accell Super Stock coil & WOW what a difference. The rich/raw gas fumes that had always been associated with my car disappeared.
Wade
« Reply #44 on: December 05, 2006 - 08:21:44 PM »
Thanks to all who posted on this thread.  I used the information and  based on video 435........I think it worked well.  I will start another post concerning the transmission soon.  It seems to  go into gear rather harshly.  And remembering that I still have more tuning to do on the engine.  Just from what little I have had it on the road....I want to be careful on rainy days!!!!!!!!!!!! :burnout: :burnout:  THANKS AGAIN, DAVID
Dave or David
