440 engine! !side item Starter stuck..!!!11/26 Not anymore, Now Videos
Author Topic: 440 engine! !side item Starter stuck..!!!11/26 Not anymore, Now Videos  (Read 7649 times)
Offline Street_Challenged73
Re: 440 engine! !side item Starter stuck..!!!11/26 Not anymore, Now Videos
« Reply #45 on: December 05, 2006 - 08:57:46 PM »
The car sounds pretty nice, David. :2thumbs:
Offline DAYLEY/CHALLENGER
« Reply #46 on: December 10, 2006 - 06:36:45 PM »
http://big-dog.us/challenger/videos.html
I think this gets you to the engine running without going to the main page of the website.
Well it gets you to the video page anyway.  The engine 2 video sounds best...David
« Last Edit: December 10, 2006 - 06:38:29 PM by DAYLEY/CHALLENGER »
Dave or David
Offline Oldschool
  • Member Since 9-05-06
« Reply #47 on: December 10, 2006 - 07:08:00 PM »
   :iagree:    She sounds great!    :2thumbs:   :ylsuper:
Ken  --  In Georgia
« Reply #48 on: December 19, 2006 - 08:39:07 PM »
Got a question...Can someone post a pic of the timing tab on the 440 that isn't painted over??  I cannot see the timing marks and it is in a tight spot to try to sand off.  I know I am supposed to be at about 8 degrees btdc. thanks, David
Dave or David
Offline ShelbyDogg
« Reply #49 on: December 19, 2006 - 09:00:06 PM »
Sorry, I looked at all of my engines here and they are all painted or small blocks or modified. Just start at the hole for zero degrees.  The first long line, about 1/2 and inch counter clockwise is 5 degrees BTDC. Second long line, 1/2 and inch below that is 10 degrees BTDC. So about 3/4 of an inch before the hole is about the 8 degrees that you're looking for.
« Reply #50 on: December 19, 2006 - 09:06:39 PM »
If you still have the timing tab in place, It extends to about 10 degrees. I'm on the fuzzy edge a little over with my bigger cam. I'm at 12-13 BTDC.
« Reply #51 on: December 20, 2006 - 01:08:01 PM »
Question.... I currently have an Edlebrock 750 on the 440.  Can I get by with a 600cfm.????  I believe the 750 is dumping too much gas in and I do want some mpg.   There is also a Torker intake involved with this installation.   :feedback:
Manual Choke
Designed and calibrated for optimum street performance in small-block and some big-block engines. Match with a variety of manifolds that include Edelbrock Performer, Performer EPS, Performer RPM, RPM Air-Gap, Torker II and other brands of similar design. Includes both timed and full vacuum ports for ignition advance. Electric choke #1478 can be added if needed. Comes with: Metering Jets – Primary .100, Secondary .095; Metering Rods – .070 x .047; Step-Up Spring – orange (5" Hg). Use our Carb Studs if needed, see installation items.
600 cfm, square-flange, manual choke ....#1405*
Replacement Main body only for #1405 (reconditioned) ....#9921*
Replacement Top only for #1405 (reconditioned) ....#9927*
Dave or David
« Reply #52 on: December 20, 2006 - 03:09:52 PM »
Manual Choke
If you have a 750 on there now, I would say that is as small as you should go with it. Is your engine stock(bigger cam)? I have an 800 on mine. If you have a Torker II intake, then that is a single plane manifold built for 2,500 RPM's and beyond. It's tough to get any kind of gas mileage with a 440, unless you have a modern tranny with an overdrive or something. Your rear gear ratio comes into play too. I get a tad more than 12 MPG hiway, but I have a big cam, Holley double-pumper carb, and headers for some performance.
« Last Edit: December 20, 2006 - 03:15:30 PM by MEKrunner »
« Reply #53 on: December 20, 2006 - 04:39:07 PM »
Found this at http://www.mortec.com/carbtip1.htm
The math formula is:
CARB CFM =
So if you had a stock, low performance production motor of 350 cubic inches and you wanted to spin it to 5000 rpms max and it had a VE% of 80%, the formula would determine a required carb CFM of 405 CFM. If you had a warmed over street performance motor of the same size, but it was capable of 7000 max rpms and it had better heads, camshaft, headers and a performance intake that raised the VE% to 95%, the formula would give you a minimum required carb CFM size of 673 CFM.
[440*5000/3456]*80%=509
[440*7000/3456]*95%=713
SO a 600 would be a reasonable compromise  :dunno:
« Last Edit: December 20, 2006 - 04:41:21 PM by bullitt99 »
« Reply #54 on: December 20, 2006 - 05:01:52 PM »
Ok. When I bought the car I was told that the engine had been worked on.  Different from stock cam, headers,
torker intake. MT valve covers (I'm sure that added 20 more horses),  Anyway  I asked about a carb kit and they don't sell these.  A new 750 is about $260. and a new 600 is $248.  Not much diff.  I guess that the old carb may have me wondering if the 750 is too much or it may be malfunctioning enough to cause me to believe it is too big.
Dave or David
« Reply #55 on: December 20, 2006 - 05:07:36 PM »
Can you expand on this? Why do you think the 750 is dumping too much gas? I wouldn't think so if it is setup right. Do your spark plugs look good(not black)? What kind of MPG are you getting, and what rear gears do you have?
Offline 6packCuda
« Reply #56 on: December 20, 2006 - 06:11:54 PM »
This is probably a really stupid question, but what is VE%?
« Reply #57 on: December 20, 2006 - 06:23:29 PM »
VOLUMETRIC EFFICIENCY PERCENTAGE (VE%) of the engine.
« Reply #58 on: December 20, 2006 - 06:28:00 PM »
Anyway  I asked about a carb kit and they don't sell these.  .
 What carb do you have?? I can't believe that you can't get a kit. You said you have a Carter, do you have a model number?
   Googled Carter Carb & got this http://carbs.partschoice.com/tech/Carter/AFB-AVS-index.html
   & http://www.aedperformance.com/Kits.htm
« Last Edit: December 20, 2006 - 06:40:07 PM by bullitt99 »
« Reply #59 on: December 20, 2006 - 09:11:10 PM »
To answer a couple of questions.  It is an Edlebrock 750 that had varnish consistancy  (sp)  gas in it when I took it apart. I cleaned it as best I could.  I actually haven't had it road worthy only to drive it in the neighborhood about 1/2 mile. When idling it seems smooth but will not take acceleration smoothly. (This may still be a timing issue)   And I really stunk up the house last weekend. Rich smell of gas.  Plug and wires  are new.  The old ones were black however it has set for 1 1/2 years without being started either.  When I do start it (cold engine) I choke it a little and then have to open the choke but hold the throttle open to keep it running until it warms a bit.
http://big-dog.us/challenger/videos.html   Listen to Engine 2 video.  This is the best it has sounded but this is as idle.
Dave or David
