Author Topic: FC7 R/T SE  (Read 57341 times)
Offline RusTy/SE
  • Just havin' fun
Re: FC7 R/T SE
« Reply #60 on: June 11, 2007 - 05:46:21 PM »
 :popcorn: Oh yeah, they're also repainting an Olds Omega among other things ::)
« Last Edit: July 27, 2009 - 10:52:11 PM by onefornow »
Russ
2001 Durango     1B4HS
1970 Challenger  JS29U
Offline RusTy/SE
  • Just havin' fun
Re: FC7 R/T SE
« Reply #61 on: June 12, 2007 - 06:07:19 PM »
  I went to the shop today to retrieve my data tag; they had pressure washed the engine bay so i took advantage an clicked these pics. The body had been painted in a bluish purple thick jel-coat with some glitter mixed in for good measure; the front wheel wells and inside the hood scoops were painted white at one time. Anyone remember this ummm...distinctive looking Challenger running around Woodward Avenue back in the 70's - 80's? I took another few shots of the front as well as on top of the cowl to try and show how the black was applied - at least on this particular car. Luckily nothing but surface oxidation behind the battery tray, phew ::)
 :working:
« Last Edit: July 27, 2009 - 11:15:15 PM by onefornow »
Russ
2001 Durango     1B4HS
Offline RusTy/SE
  • Just havin' fun
Re: FC7 R/T SE
« Reply #62 on: June 12, 2007 - 06:10:55 PM »
 :working:
« Last Edit: July 27, 2009 - 11:18:39 PM by onefornow »
Russ
2001 Durango     1B4HS
Offline RusTy/SE
  • Just havin' fun
Re: FC7 R/T SE
« Reply #63 on: June 12, 2007 - 06:12:14 PM »
 :working:
« Last Edit: July 27, 2009 - 11:20:25 PM by onefornow »
Russ
2001 Durango     1B4HS
Offline 71bigblock
    • Steve's Mopars
Re: FC7 R/T SE
« Reply #64 on: June 13, 2007 - 08:03:47 AM »
That rot makes me cringe.  I've seen too much of it on my truck.   :lol:
Otherwise it looks real solid!   :grinyes:
Offline RusTy/SE
  • Just havin' fun
Re: FC7 R/T SE
« Reply #65 on: November 14, 2007 - 09:43:51 AM »
 :working:
I promise for the duration of this Challenger's rebuild not to tempt Mr. Murphy as he has now thrown in this hilariously placed area of advanced surface oxidation to deal with :lol2: :faint: :working:  On the plus side it's now a spinning Challenger; here are some ugly shots of the bottom. Reminds me of Frankenstein in some spots :scared:
All pics now restored :picture:
« Last Edit: July 27, 2009 - 11:25:21 PM by onefornow »
Russ
2001 Durango     1B4HS
Offline RusTy/SE
  • Just havin' fun
Re: FC7 R/T SE
« Reply #66 on: November 14, 2007 - 09:48:02 AM »
 :stirpot: :poopoke: :poopoke:
The torque boxes are not pretty either...seriuosly, are Saf-T-Caps in order here??  :dunno: I have no problem instructing the shop to order them but as my car will be 99% a driver when does 'better safe than sorry cross over into 'overkill' for a driver :dunno: :dunno: As always all opines welcome :grinyes:
:working:
« Last Edit: July 27, 2009 - 11:28:10 PM by onefornow »
Russ
2001 Durango     1B4HS
Offline Chlngrcrzy
Re: FC7 R/T SE
« Reply #67 on: November 14, 2007 - 10:53:52 AM »
Wow, lots of progress.
Re: FC7 R/T SE
« Reply #68 on: November 14, 2007 - 11:43:10 PM »
Progress is looking great Russ. Keep us posted on it.   :2thumbs:
Are you sending out to media blast?
Keep Mr. Murphy out of your mind and he'll go away?
Offline RusTy/SE
  • Just havin' fun
Re: FC7 R/T SE
« Reply #69 on: November 15, 2007 - 12:39:43 AM »
Funny you should ask, going to the media blaster is, in fact, the next big move  :working:
Russ
2001 Durango     1B4HS
Offline RusTy/SE
  • Just havin' fun
Re: FC7 R/T SE
« Reply #70 on: January 03, 2008 - 11:04:53 PM »
I picked up a 4738S Carter dated H9 (August 1969). A bit early for the scheduled production date of 109(70) but still...:)
 :working:
« Last Edit: July 27, 2009 - 11:33:53 PM by onefornow »
Russ
2001 Durango     1B4HS
Offline hezzel
  • Matching numbers 383 Magnum ,727 at and 3:23 rear
Re: FC7 R/T SE
« Reply #71 on: January 07, 2008 - 08:50:13 AM »
I like the work you have done so far ,keep the pics coming :2thumbs:
1971 Dodge Challenger R/T
2019 Toyota Rav4 Hybrid
Offline RusTy/SE
  • Just havin' fun
Re: FC7 R/T SE
« Reply #72 on: February 17, 2008 - 01:25:13 PM »
Thanks hezzel. Here's several pics as motor assembly began. The pic of the piston/rod assembly shows a couple of pieces of flexible fuel hose to keep the rod bolts from accidentally nicking the crank when being inserted :thumbsup:
 :woohoo:
Russ :working:
« Last Edit: July 27, 2009 - 11:35:44 PM by onefornow »
Russ
2001 Durango     1B4HS
Offline KZ
Re: FC7 R/T SE
« Reply #73 on: February 19, 2008 - 02:08:28 PM »
ok, I am going to show my ignorance, and please, do NOT rip me a new a**hole with your answers to my inquiry. I'm only asking because if I can be so fortunate in the future, then I will have my 70 RT/SE 440-6 completely restored. It seems to me if a person is going to media blast/acid dip their car that that should be the first step so that you could see all bare metal. Following the blasting/dipping, THEN weld on your new donor metal. That way you could eliminate alot of rust scraping, old paint and primer removal, etc. and maybe alot of extra work.
Offline RusTy/SE
  • Just havin' fun
Re: FC7 R/T SE
« Reply #74 on: February 19, 2008 - 05:35:49 PM »
No problem KZ. Every shop has it's own order of doing things, the shop doing my car just happened to do it in the media-blast-last order. If i'm fortunate enough to have another Mopar, I will do much, much more of the disassembling personally. It's a learning process full of much unanticipated drama  :swear: :swear: but i have no regrets. Once the car is in my driveway i'll post businesses, contacts, friends etc. that have contributed to the end product :thumbsup:
 :cheers:
Russ
2001 Durango     1B4HS
