Author Topic: Will 5/16 fuel lines adequately supply a moderately built 440?  (Read 1320 times)
Offline Grec
« on: November 13, 2006 - 08:44:43 AM »
My '73 Challenger has a 440 in it. However, it till retails the 5/16 fuel lines from the tank to engine compartment.
I'm looking at replacing the fuel pump and wanted to know if I should step up to a 3/8 set up, or would the 5/16 work fine?
I'm thinking I would like to get somewhere around 550hp out of the motor... so nothing major, but still a big leap from what those lines were originally feeding.
Can 5/16 handle it?
1973 Challenger Rallye
- 440 Six Pack
- A833 4 Speed, 18 Spline
- FE5 Rallye Red on Black
Offline 4Cruizn
  • HEMI FISH
Re: Will 5/16 fuel lines adequately supply a moderately built 440?
« Reply #1 on: November 13, 2006 - 09:49:54 AM »
I say if you're going to have over 500HP, you need to upgrade IMO.  Don't forget the sending unit also as that needs updated too!   :bigsmile:
Offline GoodysGotaCuda
« Reply #2 on: November 13, 2006 - 10:41:33 AM »
Upgrade, the fuel line isn't very expensive. My 318 has the fuel system to supply 11's. Overkill never hurt.  :screwy: :grinyes:
1976 Dodge Warlock
Wheel & Tire Specs:Link
Offline Grec
« Reply #3 on: November 13, 2006 - 11:22:21 AM »
Alrighty then.
Added to the list. :-)
- 440 Six Pack
« Reply #4 on: November 13, 2006 - 11:28:33 AM »
$59 for stock. $95 for Stainless
http://www.gastanks.com/products.asp?dept=143
1976 Dodge Warlock
Offline Grec
« Reply #5 on: November 13, 2006 - 11:49:53 AM »
Right on.
Thanks.
- 440 Six Pack
« Reply #6 on: November 13, 2006 - 02:21:00 PM »
I ran low 12s with 5/16 "lines then they became restrictive  but they will work to about 500 hp then I upgraded to 3/8"
Offline Grec
« Reply #7 on: November 13, 2006 - 04:34:14 PM »
Gotcha. Sounds like I'd be pushing their limit with the hp I'm wanting.
Looks like 3/8 is in her future.
- 440 Six Pack
