Author Topic: Does anyone know the part number for a 3/8 Carter fuel pump? (440)  (Read 1716 times)
Offline Grec
« on: November 13, 2006 - 04:37:42 PM »
None of the parts sites I've been to list whether it's 5/16 or 3/8.
Even the Carter site doesn't say!
The block is a 68 440HP. I'm thinking I'll be setting it up like a 70 440 six-pack car.
A Carter would have been on those, correct?
1973 Challenger Rallye
- 440 Six Pack
- A833 4 Speed, 18 Spline
- FE5 Rallye Red on Black
Re: Does anyone know the part number for a 3/8 Carter fuel pump? (440)
« Reply #1 on: November 13, 2006 - 06:03:31 PM »
some info at NAPA may help    their part # same as Carter w/NFP added
http://www.napaonline.com/masterpages/NOLMaster.aspx?PageId=470&LineCode=NFP&PartNumber=M4845&Description=Fuel+Pump+(OE+Mechanical+Type)
Fuel Pump (OE Mechanical Type)
Click on image to see enlarged view
  Item#: NFPM4845
Price: $33.19
tax and shipping not included
Disclaimer: The stated price may vary from the in store price and may change at anytime.
Attributes:
Fitting Size(s):3/8"; 1/8"-27 N.P.S.F.
Gallons Per Hour:33
Pressure Rating:6.8 lb - 8.1 lb
Add To Cart
Return to Previous Page
New Search
Offline Grec
« Reply #2 on: November 13, 2006 - 08:20:27 PM »
That should do it.
Thanks!
- 440 Six Pack
« Reply #3 on: November 15, 2006 - 03:43:41 PM »
I have a hi-volume Carter pump I bought from Summit. You have to install your own fittings for the fuel lines, so a trip to Home Depot solved that problem.
Offline Grec
« Reply #4 on: November 16, 2006 - 12:29:04 PM »
What, does the high volume carter not have the 3/8" inputs/outputs?
They have the right parts at home depot? If I have to go looking, do you remember what they were called?
- 440 Six Pack
« Reply #5 on: November 16, 2006 - 05:38:58 PM »
It' been a few years, so my memory is foggy.  :banghead: I have 3/8" rubber lines going into, and out of my fuel pump. In the plumbing section I found fittings that screwed into the input/output of the fuel pump. They were tapered on each end, so you really could use any size fuel line, I suppose. Just clamp it on. If you are really at a loss here, I can probably take a pic of my setup for you.
Offline Grec
« Reply #6 on: November 16, 2006 - 08:10:07 PM »
Actually, now that I look at it, it looks like a simple brass pipe fitting. I'll just take my new pump with me and check the thread pitch against what they have at HD and I should be good to go.
I'm making a second career out of thanking you. :-)
Thanks!
- 440 Six Pack
