340 stroker kit and heads
Author Topic: 340 stroker kit and heads  (Read 775 times)
Offline farmboy70
« on: November 14, 2006 - 07:39:27 PM »
Hi everyone
 I have been thinking about what engine to put in my 73 Cuda.
I have the original 340 and was looking at a  stroker kit from  Straight line performance. Is this type of kit over kill if I would go with the 308 heads? I suppose I should outline what I want for this car.
 I want to upgrade the power,but want to be able to drive it to long distance shows and cruises(dependable ,low maintenance). It is a four speed with 355 gears. I also want the engine bay to look as stock as possible. Rpm wise I doubt it will see high rpms often mainly looking for lots of torque.
 I want to keep the original carb but may add headers as I don't have the original manifolds. Here is what I have to start with.(below)
Any links to this type of build or personal experience would be great.
 I know about as much on this type of build as I do on brain surgery! :icon16:
Thanks
Offline moper
Re: 340 stroker kit and heads
« Reply #1 on: November 15, 2006 - 10:37:15 AM »
Build a mild 416. Headers would help, but not a "must have" with your head choice. Huge torque, mild looks.
« Reply #2 on: November 15, 2006 - 01:13:19 PM »
if you are looking for moderate RPM with great torque ythe 308 heads ported should work extremely well with the combo
Offline farmboy70
« Reply #3 on: November 15, 2006 - 03:43:30 PM »
I think I will change directions a little, since I have a couple of 360's I'm going to go with one of them and moth ball the original engine. Has anyone used Straight line performance for parts? I may also scrap the total stock look also.
Offline ESGEE
  • 1970 Challenger RT/SE
    • SG´s site
« Reply #4 on: November 15, 2006 - 06:35:34 PM »
That drivetrain stand was smart :cheers:
70 Challenger RT/SE(Looking for 383 Magnum N0B196875)
70 Challenger RT/SE(Looking for 383 Magnum N0B115166)
70 Challenger SE(RT/SE clone)
69 Charger RT/SE 4speed Trackpac
70 Charger 500
Offline moper
« Reply #5 on: November 17, 2006 - 10:12:51 AM »
Smart move keeping the original engine stock. A 408 looks the same, costs the same. Runs the same.
