Author Topic: 340 vs 360  (Read 10295 times)
Offline TreeFrog
    • TreeFrog
340 vs 360
« on: November 15, 2006 - 09:18:12 AM »
340vs360
which is a better motor...why?
87 Dodge Ram     318 Blue
88 Dodge Ram     360 Grey (+)
Offline 4Cruizn
  • HEMI FISH
Re: 340 vs 360
« Reply #1 on: November 15, 2006 - 10:00:38 AM »
360 has more cubes!
Offline TreeFrog
    • TreeFrog
Re: 340 vs 360
« Reply #2 on: November 15, 2006 - 10:03:10 AM »
yes, but that does not allway mean better...I have seen many 400's that get stomped by a 340, 360, 383...
Offline matt63
Re: 340 vs 360
« Reply #3 on: November 15, 2006 - 10:04:58 AM »
360 has more cubes!
and more stroke.
Matt in Edmonton
'68 Valiant
Offline wiging19
Re: 340 vs 360
« Reply #4 on: November 15, 2006 - 10:17:16 AM »
 :chatting:  Interesting question.  Depends what kind of block your starting with for both choices is my first question.  I agree with the prior two emails about what they've said.  That is what I went to because of availability, ease of upgrading and potential power.  Of course depending on how much money you have a good case could be made for the 340 too.  I'm thinking of an aluminum block and light weight accessories.  I'm assuming you want light weight with significant power.  This is the kind of choice you have to give factors that might influence your choice.  Ball park amount of money you have for the parts, ability to do the work yourself and how your intend to use the power train (round town hot rodding, race track times, rallye contests, etc.).  :working:
Offline moper
Re: 340 vs 360
« Reply #5 on: November 15, 2006 - 10:35:02 AM »
A more easy question... What is the difference between right anf left?
Both are good engines. Both are virtually identical in terms of strengths and weaknesses. In terms of street engines, the 360 has it in my book.
Offline dimples
  • (dodgetkboy78)
    • American car and truck forums
Re: 340 vs 360
« Reply #6 on: November 15, 2006 - 12:21:19 PM »
And 400's eat 440's for lunch too.
They can all be built to make the same power, it's just your wallet, and low end torque, that will suffer.
Me?
360!
Re: 340 vs 360
« Reply #7 on: November 15, 2006 - 01:18:39 PM »
the 360 is far easier & cheaper to get initially & has more stroke both advantages in m y book
 the down side is the 360 only had cast cranks & by the time you buy a steel crank ofr a 360 you will be evry close to the entry price for the 340 , after that it will cost the same to build either
cudahob
Re: 340 vs 360
« Reply #8 on: November 15, 2006 - 02:35:36 PM »
340 is a high performance engine, the 360 is not.
Re: 340 vs 360
« Reply #9 on: November 15, 2006 - 02:38:09 PM »
360 is a high performance engine IF you do the same things to it that the 340 had like high compression , decent heads & cam
« Last Edit: November 15, 2006 - 03:27:39 PM by Chryco Psycho »
Offline dimples
  • (dodgetkboy78)
Re: 340 vs 360
« Reply #10 on: November 15, 2006 - 02:59:09 PM »
I do believe, the late 70's E58 ran as strong, as the 340's, with crap for compression.
Re: 340 vs 360
« Reply #11 on: November 15, 2006 - 04:58:38 PM »
TreeFrog,
  I can't answer your question, but as far as value goes, an E-Body with a 340 seems to be worth alot more than an E-body with a 360.   :clueless:
Offline matt63
Re: 340 vs 360
« Reply #12 on: November 15, 2006 - 05:12:07 PM »
TreeFrog,
Probably because the E body price goes down as they get newer after '71 and the newest ones had the 360s.
Matt in Edmonton
'68 Valiant
cudahob
Re: 340 vs 360
« Reply #13 on: November 16, 2006 - 04:57:48 AM »
I'm talking original factory intent, a rebuilt 360 I can agree with you, just as good.
Offline oldkimmer
Re: 340 vs 360
« Reply #14 on: November 16, 2006 - 08:56:49 AM »
I can honestly say I spanked a lot of big blocks with my little 340. But whens the last time u heard anyone with a 360 say that?
The beast has been unleashed........Thems the hazzards..........Unleash the beast......
