Author Topic: How to Launch with a 727  (Read 6405 times)
Offline tactransman
Re: How to Launch with a 727
« Reply #15 on: November 16, 2006 - 02:46:46 PM »
 HOT! HOT! :woohoo:
« Last Edit: November 16, 2006 - 02:48:29 PM by tactransman »
Terry-tactransman
Union, Mo.
Offline wiging19
« Reply #16 on: November 16, 2006 - 03:11:50 PM »
Incredible.  I've never seen a transmission that totaled before.  That was beyond my wildest dreams.  Thanks for sharing the picture.  :chatting:
Offline oldkimmer
« Reply #17 on: November 17, 2006 - 11:47:55 AM »
The sprag always takes a lickin in first when u do not have the low band applied. On stock type trans 1st is applied as soon as the trans selector is in 1. In drive all that is holding is the sprag. Some shift kits do not allow 1st band on in manual low, these should be avoided like the plague. Any trans with manual low working does not usually have  A SPRAG MALFUNCTION unless it is overstressed from many years of abuse.When doing a burnout shifting up is fine, the problem begins as soon as the wheels stop spinning as they grab traction and the trans downshifts back to 1st.. and the only thing holding is the sprag, cause your shifter is in 2nd, BANG.....trans failure There are far more chevy+ford failures than dodge.
The beast has been unleashed........Thems the hazzards..........Unleash the beast......
Offline ntstlgl1970
  • T a c o c a t
« Reply #18 on: November 17, 2006 - 05:05:45 PM »
Launching will just depend on your car and the track conditions. I have a 2800 stall speed converter, launching the car at or near that RPM results in a terrible 60 foot time, but 1900 or so works well. The track where I live (Sacramento Raceway) doesn't do much in the way of track prep for test and tune so adjusting tire pressure and launch RPM trial and error is the only way to figure it out.
Offline wart1de
    • Vivah
« Reply #19 on: November 20, 2006 - 09:05:25 PM »
Do the scattershields actually do anything? I've heard they are a waste of time and that if the box lets go parts go straight throw it ?? I'm a paranoid type of guy so I was considering installing a shield when I get around to putting the driveline back in the 'Cuda.
1973 Plymouth 'Cuda
1980 Ford Falcon XD ESP
2012 Jeep Wrangler Rubicon
Offline tactransman
« Reply #20 on: November 20, 2006 - 09:34:15 PM »
Yes ,they help.
Terry-tactransman
Union, Mo.
Offline Carlwalski
« Reply #21 on: November 20, 2006 - 11:38:42 PM »
If you're paranoid then grab yourself a Drive-shaft loop as well.
US Car Tool sell them - http://uscartool.com/body.html
My 'Cuda will have that and their subframe connectors.  :cheers:
1970 Dodge Challenger R/T
White, License Plate, 0A-5599
Offline Tubbed440
  • Suspension NinJa
« Reply #22 on: November 21, 2006 - 07:45:42 AM »
I've heard several diffenrent opinions on the subject of low band apply.  Some say you need it, some say you dont.  I for one like to have the billet steel front drum, bolt in sprag and low band apply.   :thumbsup:
Here's a discussion on the topic if you want to read up some more....
http://www.moparstyle.net/forums/showthread.php?t=70657&highlight=low+band+apply
74 Dodge Challenger
500 inch stroker, Full cage, ladder bars,
coil-overs, 4L80E, 325/50 M/T DR's....street car!
(work in progress)
Offline tactransman
« Reply #23 on: November 21, 2006 - 09:15:33 AM »
Low band apply is BETTER! Hands down, if you know how a Torqueflite works, it is obvious that low band apply is safer and stronger and gives your transmission a longer life. If you roll the sprag , it is a good chance that your case is junk!
It is harder to get a low band apply transmission to work nice and crisp with clean shifts  but in the transmission industry that separates the men from the boys!!!!! :bigshades:
Terry-tactransman
Union, Mo.
Offline moper
« Reply #24 on: November 21, 2006 - 10:08:31 AM »
Those in the know will replace the forward clutch retainer first. Then, the sprag, the valve body type, the way you do burnouts, etc, cannot result in an explosion like in the pictures. You can still hurt the trans, but the drum is what actually exploeds. And it can go with enough energy that even the steel sheilds may not contain it. I know blankets and carbon fiber cant stop the shcrapnel. Neither can floors, doors,driver's body, or roof panels. It's ugly. :eek4:
Offline Tubbed440
  • Suspension NinJa
« Reply #25 on: November 21, 2006 - 10:39:33 AM »
 :iagree:  Yea, what he said.
74 Dodge Challenger
(work in progress)
Offline tactransman
« Reply #26 on: November 21, 2006 - 11:16:50 AM »
The number one reason for a drum failure like in the picture is a drive line failure under full throttle. The transmission gets driven by the inertia of the output shaft (instead of the input shaft) and the gear ratio from that direction is an overdriven ratio , so the direct drum can be driven 20,000 plus RPM.
Centrifugal force basically "slings" it to pieces.
With a low band apply valve body it does engine braking in low gear to limit that "overdriven" RPM that can occur in low gear under full throttle. Second and third have "engine braking" no matter what type of valve body you have.
The blankets and shields don't stop it always , but you have to do all that you can do for safety.
Terry-tactransman
Union, Mo.
