the rubber bushing comes with inner & outer steel sleeves molded on to the bushing , the poly just replaces the inner rubber the steel sleeves from the original bushings are retained & reused , you do not need to press them out just clen the original rubber out , I use a propane torch to soften the rubber to get the bushing apart
