Author Topic: 440 pistons  (Read 6059 times)
Offline 170cuda
440 pistons
« on: November 17, 2006 - 07:51:23 PM »
I'm building a .030 over 440 with 516 heads stock steel crank and recond LY rods. What piston would you guys recomend to get about 10.5:1 compression out of it. It will be a mild bracket motor.
Re: 440 pistons
« Reply #1 on: November 18, 2006 - 12:16:43 AM »
Use the Speed Pro l2355F , check your deck height as it is assembled & you will be very close to 10.5 , you can taylor it with deck height & head gasket
Offline 170cuda
Re: 440 pistons
« Reply #2 on: November 18, 2006 - 08:25:12 PM »
Will I need bigger valve reliefs the heads have 2.14 1.81 valves in them.
Re: 440 pistons
« Reply #3 on: November 18, 2006 - 09:47:56 PM »
no , the reliefs will clear the valves
Offline 1 Wild R/T
Re: 440 pistons
« Reply #4 on: November 18, 2006 - 11:00:03 PM »
Should make a nice safe combo, the 516's won't breath enough to risk breaking an LY rod due to the heavy L2355F piston,  :roflsmiley:
Re: 440 pistons
« Reply #5 on: November 19, 2006 - 12:35:28 AM »
for more $$ Diamond Ross & JE all make a lighter forged piston + you will spend more on balancing depends on your budget
Offline 170cuda
Re: 440 pistons
« Reply #6 on: November 19, 2006 - 05:02:16 PM »
Just looking for a cheap reliable build nothing fancy. Thanks for the help.
Re: 440 pistons
« Reply #7 on: November 19, 2006 - 09:40:00 PM »
I could recomend some silvolite kb237's.  .010 in the hole some felpro  .042 gaskets, install some 2.14  1.81 valves, an 850 holley, open plenum intake, 3500/4000 stall 29 inch tires 430 gears and have a blast for many passes of pleasure. cam selection should be around a 3000 to 6200 rpm.  Of corse there are many combo"s, but this piston will give you what you want and last a long while.  Balancing is always a great thing, but you can get by just installing in yer shop and get going. This is a bugjet engine and low maintenance.
Re: 440 pistons
« Reply #8 on: November 19, 2006 - 10:05:15 PM »
personally I would never use KB piston , for a very little more $$ you can have a good forged piston that is indestructable
the L2355F is a stock weight piston & with the stock LY rod so it is the same as it came from the factory & the 516 heads got my Duster into the mid 11s with porting & larger valves so the heads can`t be that bad
Offline moper
Re: 440 pistons
« Reply #9 on: November 20, 2006 - 01:31:16 PM »
KB237s at 0 deck hieght is my std "solid performance" package. Nothing wrong with them when istalled and spec'd properly. They are lighter than factory, I'm pretty sure the TRW/Speed Pros are heavier actually..but I could be wrong on that one. They run quieter, and are as reliable in most stock stroke applications, and cost less than $300.
Offline Tubbed440
  • Suspension NinJa
Re: 440 pistons
« Reply #10 on: November 21, 2006 - 07:18:36 PM »
Yup.  I built a 440 when I was 17 (12 years ago) with a set of KB's zero decked and LY rods.  That motor has outlived 3 cars and is presently in a 65 coronet with a 4 speed.  I sprayed a 175 HP shot a of gas to that thing on a religious basis at the track and never had a problem with it.  Getting a motor to live is all in the tune and the machine work / set up.
74 Dodge Challenger
500 inch stroker, Full cage, ladder bars,
coil-overs, 4L80E, 325/50 M/T DR's....street car!
(work in progress)
Re: 440 pistons
« Reply #11 on: November 21, 2006 - 10:42:10 PM »
 the machinist will make or break the engine
Re: 440 pistons
« Reply #12 on: November 21, 2006 - 10:46:09 PM »
Oh so true Chryco, I build mine myself.
Re: 440 pistons
« Reply #13 on: November 21, 2006 - 10:54:28 PM »
I assemble mine & have an awesome machinist that i rely on
Offline moper
Re: 440 pistons
« Reply #14 on: November 22, 2006 - 07:57:29 AM »
   :iagree:                  Same with me.
