Author Topic: 70 cuda header panel  (Read 1619 times)
Offline moparclown
« on: November 18, 2006 - 06:42:35 PM »
How are you all?I have had this around for a bit and anyone that looked at it felt it was junk.I know that it's a one year only part so I am putting my best into fixing this.My question is What is it worth?And is it worth my time?Give me an Idea of what you have seen them sell for(swap meets,e-bay or anywhere).I know that I am nowhere near done working on it,but I will post some pic's as I go.Now if you took the time to read this please take the time to leave your opinion.Thanks The Clown
Offline 360 'CUDA
Re: 70 cuda header panel
« Reply #1 on: November 18, 2006 - 06:51:33 PM »
I had a super nice one that sold for $525
They usually go for 2 or 300   :dunno:
I did spend time on mine striping the paint but like I said it was nearly perfect.
Offline 440WhiteBoy
« Reply #2 on: November 22, 2006 - 10:26:31 AM »
hey moparclown you have some work ahead of you, but nothing too bad a couple of hours cant fix.
try to knock out that dent, hopefully you wont have to fill it with body filler.
I see them for 150 - 200 is the average going rate.
if you sell this with an after repaired pic of bare metal so they can see is best,
then have it epoxy primed.
if its worth you time? if sell it now, you might get 75 - 125 - ?
also its important about the screw holes of no broken screws or stripped out holes and after painted
like above with pics, blasted clean of any rust and explain good holes checked then you even might be upwards of 300 -?
« Last Edit: November 22, 2006 - 10:28:38 AM by 440WB »
They only see ***STARS***
when hit by a MOPAR !!!
Offline moparclown
« Reply #3 on: November 22, 2006 - 07:05:01 PM »
Thanks guys I will post a couple more pics in a couple of days.I have most of the metal worked back where it belongs,I want to take it over to my friends shop he has a mint one for the AAR he is working on and then I can check it out and make sure its as good as new.The Clown
Offline moparclown
« Reply #4 on: November 26, 2006 - 05:09:41 PM »
Wen't and did some measuring and compared my header to the one for the AAR.
