Author Topic: Help - I can't move the....  (Read 849 times)
Offline bs549
« on: November 19, 2006 - 05:59:14 PM »
torsion bar adjusting nut, so that I can change the suspension height...the nut won't budge.   :1zhelp:  I jacked up the side of the car that I'm trying to adjust, but I can't move it in either direction.
(it is the nut on the front of the suspension, directly across from the torsion bar...right? I think it's a 15/16 size)
If you've got any ideas on why I can't adjust it, or if you have a picture of the nut I'm suppose to be adjusting, I'd appreciate it.
Thanks!
Alaskan_TA
Re: Help - I can't move the....
« Reply #1 on: November 19, 2006 - 06:08:18 PM »
Here is a photo, the bolt is circled in red.
Offline JS27N0B
  • Member since Jan 28th 2003.
« Reply #2 on: November 19, 2006 - 06:33:19 PM »
Apply lots of penetrating fluid and let is sit overnight, try moving it both directions to break it loose. If still will not move, try a little heat on the swivel that the bolt goes through.  Don't forget if you change your ride height you will need to re-align the front end.
*edit, make sure you are trying to move the bolt circled in the above picture.
« Last Edit: November 19, 2006 - 06:47:21 PM by JS27N0B »
2013 Tige' RZR 343hp
Offline vinb
« Reply #3 on: November 19, 2006 - 06:41:52 PM »
Go by the photo Alaskan_TA posted. Use a 3/4 " socket, the 15/16" nut is for the lower control arm. You don't want to touch that one.....
Offline bs549
« Reply #4 on: November 19, 2006 - 07:27:14 PM »
Thanks All!!  The pic is great, as I was trying to adjust the wrong thing (the factory manual I'm using was vague at best for pointing out the adjusting nut).  I'll give it a soaking and try it out tomorrow.
Thanks!
 :ylsuper:
« Reply #5 on: November 19, 2006 - 07:59:17 PM »
make sure you jack the car up & remove as much load from the bolt as possible
