Author Topic: 360 flywheel  (Read 814 times)
Offline bluecuda360
360 flywheel
« on: November 19, 2006 - 08:16:52 PM »
Is a flywheel from a truck 360 the same as a 360 car flywheel?I know they are externally balanced,cast crank,but are they interchangable? :clueless:
Re: 360 flywheel
« Reply #1 on: November 19, 2006 - 08:19:34 PM »
MY guss is No but it depends which tranny the truck had , if it has 130 teeth yes it will swap if not you need a 130 tooth flywheel
 BTW a customer has 2 new 360 flywheels available & I am sure he would make a deal in 1 or both if needed
Offline bluecuda360
Re: 360 flywheel
« Reply #2 on: November 19, 2006 - 08:28:36 PM »
Thanks Chryco,I think it was a 143 tooth?So that wouldn't work,saw it on ebay.Mine looks like it has some heat stress cracks in or something.I dont know if those come out when resurfaced or not.Could you let me know on the flywheels you mentioned?Thanks again.
Re: 360 flywheel
« Reply #3 on: November 19, 2006 - 08:47:45 PM »
you have a PM
