Author Topic: M-1 intake  (Read 3193 times)
sleepychallenger
M-1 intake
« on: November 20, 2006 - 06:23:42 PM »
any opinions on the mopar m1 intake
Re: M-1 intake
« Reply #1 on: November 21, 2006 - 12:54:22 AM »
single plane or dual plane or all out race / raised port etc ?
sleepychallenger
Re: M-1 intake
« Reply #2 on: November 21, 2006 - 06:51:10 AM »
im looking into the dual plane
Offline moper
Re: M-1 intake
« Reply #3 on: November 21, 2006 - 08:03:38 AM »
The dual plane IMO is a waste of money. There are better ones available for less or similar money. Ones like the Performer RPM. The stock intakes are pretty good, so really in the Performer series or M1 dual plane, you are just getting a weight savings over iron. The M1 single plane I've used a bunch, and I recommend it on a lot of builds. A good choice for a smaller plenum single plane is the Holley Street Dominator.
sleepychallenger
Re: M-1 intake
« Reply #4 on: November 21, 2006 - 10:56:25 AM »
tell me more. i want somthing that will bolt on and it has to have that dash pot (or what ever that thing is) hole in the manifold so that I can bolt that in. i want something that will save weight and give a bit more performance
Offline vinb
Re: M-1 intake
« Reply #5 on: November 21, 2006 - 02:54:49 PM »
I have a Weiand #8007 on mine, its a dual plane high rise spred-bore just like the old LD340 Edelbrock. They also make #8022 dual plane for a square bore mount. Good to 5800 rpm in my engine..
Re: M-1 intake
« Reply #6 on: November 21, 2006 - 04:18:59 PM »
I'm sorry I don't know what you mean by this.  :clueless: I second moper's recommendation of the Holley Street Dominator.
sleepychallenger
Re: M-1 intake
« Reply #7 on: November 21, 2006 - 04:43:26 PM »
i mean the hole right next to the carburetor opening. dont know what it is called, think its for the choke. will all of these other intakes fit under the stock flat hood
Offline oldbadger
Re: M-1 intake
« Reply #8 on: November 21, 2006 - 05:15:23 PM »
which engine first off ?
 the Street dom is a great intake for big blocks , there is NO way a RPM will fit under a stock hood If you want to use an air cleaner
Re: M-1 intake
« Reply #9 on: November 21, 2006 - 05:20:00 PM »
Ahh,
  Gotcha now.  :thumbsup: I have the Holley Street Dominator on my car. It was a flat hood car, until someone put on the T/A scoop. I use a K&N drop-down air-filter, and have about 1/2 inch to spare. Unless you go with a drop-down air-filter, this won't make it.
Offline vinb
Re: M-1 intake
« Reply #10 on: November 21, 2006 - 05:46:55 PM »
Are we talking about a big block?????? If so,  mine is a small block, so my manifold obviously wouldn't work..Sorry...
Re: M-1 intake
« Reply #11 on: November 21, 2006 - 06:10:02 PM »
We are talking big block. Sorry about the confusion.
sleepychallenger
Re: M-1 intake
« Reply #12 on: November 21, 2006 - 07:24:54 PM »
ok, sorry for the confusion. i have the 383 mag and was hoping to use the dual snorkle factory air cleaner. wasnt sure what would fit under the stock flat hood. please advise
Re: M-1 intake
« Reply #13 on: November 21, 2006 - 10:40:56 PM »
the M1 will work but it i sjust an alum version of the factory intake , Weiand ahs a couple of low dual plane intakes as well & the Holley Street Dom works great If you can find one , they are not available new any more
 the Eddy RPM is never going to fit under a flat hood with a stock air cleaner
Re: M-1 intake
« Reply #14 on: November 21, 2006 - 10:44:49 PM »
I just seen today an add saying the new holley street dom is now again being made and ready to sell. You might call summit. GregZ sent me some tools today and in his add was the intake. He sells them now too.
