Author Topic: Project "Endless Challenge" 4l80E, dry sumped 500 wedge  (Read 70833 times)
Offline IMNCARN82
  • LeDZeP
Re: Tubbed440's Street pounder 74 Challenger project
« Reply #60 on: November 27, 2009 - 07:41:33 PM »
 :faint:
71' Demon
75' Duster
87' Conquest TSI
56' Plaza
Boulder CO
Robert    "cuda bob"
Offline Tubbed440
  • Suspension NinJa
« Reply #61 on: November 28, 2009 - 08:33:00 PM »
Did a little more work today.  Took me a while to get my tungsten balled correctly to get a good burn.
Made the plenum parts today too.
Took a while to get it dialed in.  I'm not exactly there yet, but getting there.
74 Dodge Challenger
500 inch stroker, Full cage, ladder bars,
coil-overs, 4L80E, 325/50 M/T DR's....street car!
(work in progress)
Offline conv340
    • Myspace CaMopar
« Reply #62 on: November 29, 2009 - 11:38:11 PM »
Just caught up on your project. You sure know how to make a lot of work for yourself  :grinyes: I like it! Love to see this kinda stuff.
Two models, Two makes, One year, One body.
Offline Tubbed440
  • Suspension NinJa
« Reply #63 on: November 30, 2009 - 07:33:21 PM »
Yea, well, better than shelling out money that I don't have.  :smilielol:
Made a little more progress tonight after work.  This thing is coming together really well.  Better than I expected, that's for sure.
I think I'm starting to get a hang of this aluminum TIG stuff.
Here's one side fitted to it's plate.
Twins!!!
Top and bottom are now fitted.
Now we're getting somewhere.
I actually installed the top portions on the intake runners up-side down.  You can see the lower portion of the plenum looks a little wide because of that.  I'll take it apart and change that tomorrow.
All in all, I think it's going to look like one sexy beast!!!
74 Dodge Challenger
(work in progress)
Offline Kapteenikosmos
« Reply #64 on: December 01, 2009 - 03:32:26 PM »
Great work with the intake!  :ylsuper:
Does the GM tranny fit the Challenger without modifying the front crossmember?
Ville
1967 six banger Mustang
1973 Challenger (under restoration)
1997 Lincoln Mark VIII LSC (daily driver)
Offline Tubbed440
  • Suspension NinJa
« Reply #65 on: December 01, 2009 - 07:37:16 PM »
Well, to tell you the truth, I have not gotten that far yet.  I've got my engine at work right now along with the trans, and I'm using the engine as a fixture to weld the intake up.  After I finish the intake, I'll take all this stuff home and try and fit it in the Challenger.  I would imagine to get my driveline angle right that I will have to cut the trans tunnel out and modify the rear crossmember kinda like Nstgl did on his challenger to get that trans of his to fit.
74 Dodge Challenger
(work in progress)
Offline Oldschool
  • Member Since 9-05-06
« Reply #66 on: December 03, 2009 - 12:47:06 PM »
Lookin' Good!    :2thumbs:
Ken  --  In Georgia
Offline Tubbed440
  • Suspension NinJa
« Reply #67 on: December 03, 2009 - 09:35:06 PM »
Got some more done this afternoon.  I'm not so sure I like this, hence the reason I have not welded it all the way up yet.
Here's some red-neck fixturing to hold the throttle body mount while it gets tacked in. :lol:
Here it is all tacked up.
74 Dodge Challenger
(work in progress)
Offline The Cuda Guy
  • Support Our Troops
  • Pearl Harbor, HI
    • C-C.com
« Reply #68 on: December 03, 2009 - 10:05:09 PM »
That is awesome work. You got some tallant bro!
Don
Member Since January 14, 2002
Offline Tubbed440
  • Suspension NinJa
« Reply #69 on: December 04, 2009 - 04:26:51 PM »
I'm definitely not a pro at this, but I did some reading and changed a couple things (the tungsten and some of my method) and got a little better results.  I have now finished welding the bottom part and plenum of the intake.  Now I need to make the frame for the top and weld that in - then weld the injector bungs in.  After that, mount the fuel rails, the top and let it ride.   Oh, and I need to go inside the manifold and grind down the runner welds and epoxy all the seams.  This will make it easier to smooth out on the inside.
Here's a couple shots of the finished welding (well, for today at least).
Again, not the best in the world, but the next one will be a lot better. :nod:
74 Dodge Challenger
(work in progress)
Offline ntstlgl1970
  • T a c o c a t
« Reply #70 on: December 06, 2009 - 11:00:27 PM »
Damn that looks great! I like it
Offline Tubbed440
  • Suspension NinJa
« Reply #71 on: December 07, 2009 - 05:25:27 PM »
Started blending everything in today.  I need to go by and get some more material before I make the top, so I did this to help get me a little closer to being done.   You can see in this pic there are some low spots in the runner that I will have to use Dev-con epoxy on to bring them up.
Some of them are perfect though.
It's tough to weld the thin to the thick and not get heat distortion or pits - you can see that here.
Here's the inside where I welded the runners to the plenum.  Knowing what I know now, I would have just left them un-welded and used the epoxy to seal them in.  I'm not sure what I'm going to do about that just yet, but I may just grind them flush with the plenum face - or take the easy way out and epoxy them to smooth them out.
All of the inner seams in the plenum are getting epoxy to help smooth them out also.
74 Dodge Challenger
(work in progress)
Offline Tubbed440
  • Suspension NinJa
« Reply #72 on: December 09, 2009 - 09:04:22 PM »
Welded and machined the seal rail for the top of the plenum today.  Hopefully, I'll get a whole lot further tomorrow.
74 Dodge Challenger
(work in progress)
Offline Tubbed440
  • Suspension NinJa
« Reply #73 on: December 09, 2009 - 11:04:32 PM »
Got the holes drilled and tapped in the plenum seal.  Crap part is, I need to re-weld it because I got over-zealous making everything flat and cut my weld down to nothing.  It cracked in a few places when I started drilling and tapping.  No biggie.  Nothing a little heat can't solve.
Here it is with it's new lid.  This one is going to hit the scrap pile.  I should have looked at it better before I cut it out.  It's got a TON of scratches on it that will not buff out. :lol:
Tomorrow, I'll cut the injector bung holes and weld those in.  There's a couple more things to do it, but none that need the engine as a jig anymore.
74 Dodge Challenger
(work in progress)
Offline Tubbed440
  • Suspension NinJa
« Reply #74 on: December 10, 2009 - 12:14:30 PM »
Fuel rail bungs......
74 Dodge Challenger
(work in progress)
