Author Topic: Mopar Performance Leaf Springs - Need More Height  (Read 3073 times)
Offline oldred
« on: November 23, 2006 - 01:41:23 PM »
So in another one of my boneheaded moves, I replaced the leaf springs on my car with Mopar Performance leaf springs thinking my car was sagging. Well, they're the same height, and the car wasn't sagging. Here's the deal. I'm looking to get at least 2-3" over stock ride height in the back. Here's the reason, I've got these damn headers which hang down low, and I want to lift the front end and rear end so I've got a minimal rake and don't scrape on every bump. How do you guys suggest I do it? I could use lift blocks, but that would mean doing a spring over, and I'm just not that committed yet. I don't want to use air shocks either (I lost a hose on the highway and the whole back of the car dropped which got exciting really quickly).
 :banghead:
Offline Oldschool
  • Member Since 9-05-06
Re: Mopar Performance Leaf Springs - Need More Height
« Reply #1 on: November 23, 2006 - 03:51:29 PM »
Not sure about the springs, but taller tires will add some clearance next time you buy tires.....      :cooldancing:
Ken  --  In Georgia
« Reply #2 on: November 23, 2006 - 04:25:39 PM »
oldred, The ultamate solution, according to many folks here, seems to be a company called Springs & Things aka Espo. If you do a search under suspensions on this board for Espo leaf springs you will find dozens of posts on this very topic. The bottom line is the leaf springs they sell can be ordered any way you want, seems the basic replacements are about 175 with add on $s for extra arch + shipping. I believe you can get what you want for something around  $300. http://www.espo.com/
« Last Edit: November 23, 2006 - 07:56:15 PM by bullitt99 »
Offline 422STROKER
  • Member Since 6/3/06
« Reply #3 on: November 23, 2006 - 05:52:37 PM »
Maybe a good alternative at this point would be to have your new MP Springs arched at a local spring shop.
Good Luck
Tom :burnout:
Tom
« Reply #4 on: November 23, 2006 - 09:19:32 PM »
Good Luck
Tom :burnout:
 I agree
Offline 71340RT
« Reply #5 on: November 23, 2006 - 10:05:19 PM »
If you don't get them re-arched I would use espo as I have bouth 2 sets of springs from them in the last 2 years. The set on my Cuda was new Mopar Performance springs and they set low and were pretty stiff riding. I got 1 inch over stock and they lifted my rear end just the way I wanted it.
70 Plymouth Cuda 340 4-speed
2003 Dodge Stratus RT coupe
2014 Ram Express 5.7 Hemi 4X4
Offline 4Cruizn
  • HEMI FISH
« Reply #6 on: November 23, 2006 - 10:23:51 PM »
I had a set made for the hadtop because the wheels rubbed.  Still have them if you're interested.  Just replaced them with drag springs.
Offline vinb
« Reply #7 on: November 24, 2006 - 07:35:29 AM »
Get the ride height you want with all the weight in the car, spare tire, jack, 3/4 tank of fuel, correct wheel/tire combo. Then adjust your torsion bars to the height, raise the back of the car to where you want it. Measure and then take them out and bring to your local spring shop. Have him press in new front bushings and get new shackle bushings paint them and your good to go. Now you could sell your new ones or trade them for somrething else...Got mine done for $90.00 pair. with new clamps and front bushings.. Good Luck......
Offline oldred
« Reply #8 on: November 29, 2006 - 06:01:34 PM »
Cool, thanks guys. I had done a search and knew about the ESPO springs, but I was trying to avoid buying yet another set. Off to the leaf spring shop it is.
