Author Topic: Fuel system questions  (Read 716 times)
Offline 74 340 4speed
« on: November 23, 2006 - 05:30:13 PM »
I was working on the 'Cuda today, and I got a new fuel line and fuel pump installed.  I took out the gas tank and it has four vent hoses going to a small box that a return line goes to.  What is this small box with the 4 outlet lines?  Do I need to keep this on the car even though the return line isn't being used? (I have a holley carb)  Are these vent boxes reproduced?  Mine is pretty rusty and nasty looking.
Andy
1967 Camaro SS: 406 sbc 505 hp/506 ft lbs|4 speed|Posi|3.73s
1969 C/10  350|Turbo 350
1969 Dodge D300 318|4 speed|Dana|4.88s
1972Nova: 350|Turbo 350
1974 'Cuda: 340|4 speed|Dana 60|4.10s|posi
1999 Camaro SS: Auto|Longtube Headers|True Duals|TT2s
2013 Challenger R/T: 6 speed|Hurst with pistol grip|mopar performance exhaust|super track pak
Re: Fuel system questions
« Reply #1 on: November 23, 2006 - 09:27:30 PM »
the "box" traps fumes , it could be removed but you have to have a vent on the tank or it will create a vacuum & stop fuel flow , in 70 there was a line run over 1 ' higher then the tank into the trunk & back out into the frame rail you could do something similar for yours
 I have never seen a repro vent trap
