Author Topic: 440 Magnum to 440 Six Pack ???  (Read 6356 times)
Offline Madmax440
« on: November 23, 2006 - 06:27:26 PM »
Would it simply be a matter of changing the intake manifold and changing the carbs to change my 440 Magnum to a 440 Six Pack ??? If so, is this unadvisable for any reasons ???  Lets keep in mind that it was originally a 318 car, so we are past that issue.
daves70
Re: 440 Magnum to 440 Six Pack ???
« Reply #1 on: November 23, 2006 - 06:51:34 PM »
Yes, that is pretty much all there is to it if you have the right cam. Take my word for it, SIX-PACK setups are a lot more touchy to deal with than a 4 bbl. Harder starting, but the prestige is worth it! :grinyes:
Alaskan_TA
« Reply #2 on: November 23, 2006 - 08:50:01 PM »
If tuned right they start right up. No reason not to do it at all.  :thumbsup:
Barry
daves70
« Reply #3 on: November 23, 2006 - 09:15:39 PM »
If tuned right they start right up. No reason not to do it at all. So how do I tune my right?? I've spent several hundred dollars with a mechanic that has drag raced mopars for 20 years, and the car still starts hard. After it is warmed up it starts and runs fine. I know several people on this forum have had the same problem.(Chevy convert)s one.
« Reply #4 on: November 23, 2006 - 09:29:31 PM »
I have set up more than 20 systems in the last 3 years , unless the crabs have some internal problems thay should be easy to tune in . There are several members here that I have tuned their 6 pack systems , need me to fly down ?
daves70
« Reply #5 on: November 23, 2006 - 09:35:47 PM »
Maybe. I have headers on my car as opposed to the original dual exhaust with stock manifolds. After it sets for a couple of days it starts after cranking the hell out of it and then smokes like hell untill it warms up. After that it starts and runs fine. Has to be a choke issue.
« Reply #6 on: November 23, 2006 - 09:38:45 PM »
sounds like it to me , the choke spring is adjustable on the original units
Offline Madmax440
« Reply #7 on: November 24, 2006 - 10:08:38 AM »
Thanks Guys. Any suggestions on intake manifold/carbs ???
« Reply #8 on: November 24, 2006 - 10:17:55 AM »
Umm there were 3 -6 pack intakes that I know of , the eddy STR cross ram [discontinued decades ago ], The Weiand Tunnel ram [discontinued years ago ] & the Eddy Street Intake [still available ]& the Holley carbs Still avaialable
 never did figure out why Holley makes carbs but no intake & eddy makes the intake but no carbs  :clueless:
Offline chevyconvert
  • HvacMan
« Reply #9 on: November 24, 2006 - 10:46:23 AM »
Dave..I got tired of that whole hard starting leaking thing. I figure with a six-pack car the fuel system has to be in order so here's an update:
With the following new parts: gas tank, 3/8'' sending unit, fuel lines, filter, fuel pump, vapor canister and total rebuild of all three carbs...drum roll....surprise she start's right up :thumbsup:
But now if I can just get the g.d#!*ed valve covers to seal :swear:, I could move on to the next issues with the car. Is it possible that my aftermarket pcv valve is undersized for a 440 ?
« Last Edit: November 25, 2006 - 09:39:21 PM by chevyconvert »
Eric
Bay Area California
Offline Madmax440
« Reply #10 on: November 25, 2006 - 09:33:32 PM »
I am really having second thoughts if its going to be like that. I do plan on taking to a local performance shop though.
« Reply #11 on: November 26, 2006 - 01:54:47 AM »
set up correcxtly you will never regret it
Offline kingtroll
« Reply #12 on: November 26, 2006 - 05:43:12 AM »
I have many things to do to my car before I feel it's "finished" but what do you think about the six pack for the 340? I saw this setup on promaxcarbs website.
1974 Barracuda
« Reply #13 on: November 26, 2006 - 08:07:21 PM »
I love the 6 pack good milage & great power , with the Promax mods it will be better than stock for sure
Offline kingtroll
« Reply #14 on: November 26, 2006 - 08:15:38 PM »
Sounds good...I have the promax site in my favorites :bigsmile:
1974 Barracuda
