Author Topic: comp EX275HL hows it run?  (Read 4419 times)
« on: November 24, 2006 - 08:20:47 AM »
Anybody try one? I am wanting to.   I got 10.2 compression, 3500 stall 391 gears, 214/181 906 heads. 2 inch headers. Any one else try it?
Offline Oldschool
  • Member Since 9-05-06
Re: comp EX275HL hows it run?
« Reply #1 on: November 24, 2006 - 09:01:46 AM »
What are the specs of this cam?    :dunno:    Might know more about it's characteristics if we knew that....    :cooldancing:
Ken  --  In Georgia
« Reply #2 on: November 24, 2006 - 10:02:32 AM »
I won`t use Comp cams in a Mopar
Offline tactransman
« Reply #3 on: November 24, 2006 - 11:38:10 AM »
How come C.P. ? Educate me. :grinyes:
Terry-tactransman
Union, Mo.
« Reply #4 on: November 24, 2006 - 12:26:10 PM »
most their grinds are designed for small block chevs , don1t belive me ? virtaully any Mopar grind is listed with exactly the same part # in the small block chev listings , this means that tthey are not taking advantage of the larger .904" diameter lifter that Mopar uses & in every case where I have replaced a Comp Cam with an Engle /UltraDyne / or lunati I have seen proven gains of 20+ hp , I replaced a Comp Cam in a 440 this spring & the rwhp went from 274 to 345
Offline tactransman
« Reply #5 on: November 24, 2006 - 12:36:31 PM »
So a custom grind is OK?
Do you like all the Mopar  "purple shafts"?
« Last Edit: November 24, 2006 - 01:04:36 PM by tactransman »
Terry-tactransman
Union, Mo.
« Reply #6 on: November 24, 2006 - 02:01:00 PM »
the Purple shafts still work very well considering they were designed int he 70s
I like soem of the newer grinds better thoguh
Offline Oldschool
« Reply #7 on: November 24, 2006 - 02:12:02 PM »
 I am running a Comp Custom grind roller set up in the Beast.   Runs great, sounds great, and so far has held the correct valve lash quite well.  I have tried to look it up on the Comp Cams website and there is not any part or grind number anywhere close.  Must be a top secret stealth cam...    :smilielol:    :cooldancing:
Ken  --  In Georgia
Offline Super Blue 72
    • Phil's Super Blue '72
« Reply #8 on: November 24, 2006 - 09:05:15 PM »
That explains a lot to me!
I had one in the 80's and the box said "chev" on it!  :faint:
« Reply #9 on: November 26, 2006 - 09:42:45 PM »
Sorry guys, I was called out on an emergency job when I posted. I had to fly out to Pittsburg then drive into Wheeling WV and go south for about 40 miles, so I'm stuck here for 1 more day.  Back to my post tho...
The 275 is a mopar grind and I have only ran comp cams. The dart runs 10.20's  and my 72 cuda will run a 7.96    It makes 1028 hp and this is on comp cams. I often have them grind my own designs. One of the mags did a test on a 440 with the 275 and it made like 538 horse from what I was being told. I have no proof. So I know nothing myself about this 275 cam as it stands. But it's just a street car as it is. If I was drag racing in this car, I would be running my handicap dial in so the hp gain or loss isnt a factor since you race yorself anyways. I just was wondering if anyone had tried this cam themselves....ALAN
Offline Jacksboys
  • Here Since 08/28/06 GEORGIA
« Reply #10 on: November 27, 2006 - 01:00:53 AM »
What would you suggest for a 8.5 to 9:1 360, stock iron heads with 2.02/1.60 valves, Performer intake, 600cfm edelbrock, 4-speed overdrive unit, 3.23 gears, in a 3400lb car?  (Non-Mopar Performance)
My father is going to refresh his motor in his 74 Dart in a couple of months.
Offline MJS73
    • Mike's 1973 Challenger
« Reply #11 on: December 07, 2006 - 07:26:43 PM »
 :popcorn:
www.mikes73.com
« Reply #12 on: December 07, 2006 - 09:04:38 PM »
I bought the cam from comp yesterday, and it showed up today. I am commited now so when the engine is complete, I will know then. I figure it will work good with my 6pk set up. Not looking for a large amount of HP. The car won't be raced. Just some average cruising.
Offline 72hemi
  • MEMBER SINCE JANUARY 2006
« Reply #13 on: December 08, 2006 - 05:34:39 PM »
All of my friends that have run Comp Cams have ended up repleacing them with another brand becuase the kept breaking valvetrain components from cams all the way through.
1996 Dodge Viper GTS Coupe
Offline firefighter3931
« Reply #14 on: December 15, 2006 - 06:06:31 PM »
The xehl series are nice cams....904 mopar lifter designs and fast rate of lift. A buddy has that stick in his 408 smallblock stroker with e-heads and it runs great. Idles well, lots of manifold vacuum for power brakes and easy tuning. I think you'll really like it.  :2thumbs:
Ron
68 Charger RT street/strip Bruiser & 70 Charger RT 440-6pack the ultimate Cruiser
