Author Topic: Challenger hood popping up  (Read 1655 times)
Offline Madmax440
« on: November 24, 2006 - 04:17:31 PM »
Is it just me or do others have problems with the hood constantly raising up a little by the windshield ??? I remember my 1970 having the same problem. I am constantly pushing it back down.
71challengher
Re: Challenger hood popping up
« Reply #1 on: November 24, 2006 - 04:22:54 PM »
I have the same problem with my 71.
Offline Oldschool
  • Member Since 9-05-06
« Reply #2 on: November 24, 2006 - 04:31:22 PM »
I think Chryco can tell ya how to fix those.........     :cooldancing:
Ken  --  In Georgia
Offline chevyconvert
  • HvacMan
  • Member since November 04, 2005
« Reply #3 on: November 24, 2006 - 04:47:33 PM »
on older cars like these I've always shut them in increments, kinda up and down see-saw action 6'' or so at a time as you shut them down. seems like just pulling 'em down in one motion puts a strain on them that causes the lifting.
Eric
'70 Hemi Orange RT/SE 440 Six Pack Pistol-Grip 4 speed
Bay Area California
Offline farmboy70
« Reply #4 on: November 24, 2006 - 05:57:53 PM »
Try adjusting your hinges, start with the lowest setting in the rear two  closest to the fire wall and raise the front of the hood untill the front bolt is midway, this will lower rear of the hood to the rubber stops at the cowl when closed.
Offline FY1Cuda
« Reply #5 on: November 24, 2006 - 06:30:06 PM »
I was actually going to ask about this too.  I'm having the hardest time getting my Cuda's hood to sit without the back popping up.  No matter what adjustments I do, it always seems to have this play.  Is this a sign that my hinges are bad?  I spent about 5 hours fooling around with the hinges this afternoon, and didn't get anywhere.  I managed to get the gaps all straight, and the hood when it is pushed down is even around the edges, but it has upwards play.   :dunno: :clueless: :banghead:
Offline Challenger6pak
« Reply #6 on: November 24, 2006 - 07:09:06 PM »
It sounds like your hinges need rebuilt to take the "play" out of them.  Then they won't pop up in the back.
« Reply #7 on: November 24, 2006 - 08:46:12 PM »
Farmboy has it right , raise the front of the hinge , loosen all 3 bolts & have some lift the front of the hood until the bolt is near the middle of the front slot & tighten it up , the hood should pull down level when closed
« Reply #8 on: November 25, 2006 - 04:27:41 PM »
All I had to do was put a little oil on my hinges.  :grinyes:
