Author Topic: What are the best heads for a hot street 383?  (Read 3198 times)
Offline FM3V6M
  • TX9 383 4spd
    • mytx9cuda
« on: November 24, 2006 - 09:43:06 PM »
906? 915? 452?
sleepychallenger
Re: What are the best heads for a hot street 383?
« Reply #1 on: November 24, 2006 - 10:26:43 PM »
i want to know as well.  :jumping: :crazy:  :swaying:
« Reply #2 on: November 24, 2006 - 10:53:49 PM »
my choice woiuld be 915 or 516 ported with 1.81 exhuast valves
Offline 72hemi
  • MEMBER SINCE JANUARY 2006
« Reply #3 on: November 24, 2006 - 11:20:40 PM »
I have a set of 906 heads that I bought from a friend whos' brother ran them on a Road Runner with a 383 that ran 10's. Not sure how the rest of the car was setup, but pretty sure it was a street car.
1996 Dodge Viper GTS Coupe
Offline 1 Wild R/T
« Reply #4 on: November 24, 2006 - 11:50:53 PM »
If your gonna run iron heads at least the 915 & 516 are easy to setup for quench, the 915's have better ports & some have bigger valves...
If your not familiar with it, quench is a close clearance in the combustion chamber that creates turbulance causing a more complete burn with less likelyhood of detonation...To make it work properly with 906's requires machining the combustion chambers & special pistons that also need machining...
http://racingsecrets.com/article_racing-10.html
« Reply #5 on: November 25, 2006 - 01:16:32 PM »
I always install hard exhaust seats in the heads so modifiying the 516 to take 2.08/1.81 is easy , I do not recoomend using 2.14 intakes for a 383 though, so the only real difference between the 915 & 516 is the small hump in the intake port floor
Offline 440Charger
« Reply #6 on: November 25, 2006 - 04:24:06 PM »
Hi Chryco - why do you not recommend 2.14 intakes on the 383?  Just curious because I put 2.14/1.81 on my 440.
I love my 440...but it's not loving me back...yet
« Reply #7 on: November 25, 2006 - 06:12:34 PM »
it takes a lot of engine to really Use the 2.14 valve in Iron heads , the gains on the exhaust side are there no mattter what CI the engine is but the intake doesn`t gain much unless you are stroking or taking the engine far higher in RPM
Offline 440Charger
« Reply #8 on: November 25, 2006 - 07:04:04 PM »
Interesting.  Well we're trying to pump more a/f down the intake...bought a 120gph mech fuel pump that we'll be installing in the spring.  We're running lean (you may remember me) and we're working on a solution.  Hopefully we'll take advantage of the 2.14 intake by the time we're done modding.
« Reply #9 on: November 26, 2006 - 01:50:06 AM »
I hope you can get it solved as well
Offline moper
« Reply #10 on: November 27, 2006 - 06:04:36 AM »
All depends on piston choice. 383s are farily limited as far as street type flat top pistons. They are all low compression when installed int eh block. I have built several with open chamber heads, all have 2.14/1.81 valves for several reasons. If I was planning a build this afternoon, I would go for 915s if iron heads had to be used. But, it will take a bit of $$ to make any iron heads brand new again. So looking at it from a growth and expense direction, the new MP aluminum (Edelbrock produced but straight plug) heads, or the Edelbrocks themselves would be first choice.  Edelbrock RPMS are cheaper, and once an iron head is done properly and ready to run, they will cost within a few hundred of the RPMs.
Offline Tubbed440
  • Suspension NinJa
« Reply #11 on: November 27, 2006 - 04:10:02 PM »
 :iagree:   Listen to this man.  He's hit the nail on the head....so to speak. :thumbsup:
74 Dodge Challenger
500 inch stroker, Full cage, ladder bars,
coil-overs, 4L80E, 325/50 M/T DR's....street car!
(work in progress)
Offline FM3V6M
  • TX9 383 4spd
    • mytx9cuda
« Reply #12 on: November 27, 2006 - 05:20:29 PM »
Thanks for the info guys!!!
Offline 1 Wild R/T
« Reply #13 on: November 27, 2006 - 05:28:46 PM »
I agree as well, basically what I was saying in my above post, just didn't spell it out so clearly as some here seem to oppose running Edelbrock heads...Best bang for the buck you can do to you big block IMO
Offline Tubbed440
  • Suspension NinJa
« Reply #14 on: November 27, 2006 - 08:46:23 PM »
Man, that's a shame.  I guess it could decrease the value if you're going for that "concourse" restoration though.
74 Dodge Challenger
(work in progress)
