Author Topic: pistol grip rattle  (Read 1586 times)
Offline chevyconvert
  • HvacMan
  • Member since November 04, 2005
pistol grip rattle
« on: November 25, 2006 - 10:26:41 AM »
my shifter has a constant buzzy rattle sound while driving that goes away if you have you place your hand on it.
Any idea what it is and how to make it go away?
Eric
'70 Hemi Orange RT/SE 440 Six Pack Pistol-Grip 4 speed
Bay Area California
Offline pink panther
Re: pistol grip rattle
« Reply #1 on: November 25, 2006 - 12:49:00 PM »
if it is the samesound as mine, it is the top cap showing the shift pattern, it rattles, I haven't figured out how to tighten it up, but put a samll baed of silicone under it and it has stopped ratteling.
« Reply #2 on: November 25, 2006 - 01:07:15 PM »
Take the shifter out of the car clean & rebuild it & pack it with grease
  • HvacMan
« Reply #3 on: November 25, 2006 - 08:54:38 PM »
definitely lower than the top cap.
Where would be the best place to look for removal/rebuild/replacement info?
Eric
Bay Area California
Offline Robb
« Reply #4 on: November 26, 2006 - 01:32:21 AM »
Mine just needed the grip screws tightened, and noise went buh-bye
70 Challenger SE  (440 SIX PACK / Keisler 5 speed, R/T SE replication)       68 Sport Satellite Convertible 383 Super Commando / 727  Survivor
2002 Trans AM WS6 convertible:  DD
1999 4Runner 4x4:  lifted-locked-armored  expedition vehicle
1990 Jeep XJ 4x4:  Front Dana 60, GM-14bolt rear, 3 link, 4link, 5.38 detroits, beadlocked 40's, stretched to 110" wb  Rock Crawler
« Reply #5 on: November 26, 2006 - 01:49:21 AM »
Factory service manual
Offline ShelbyDogg
« Reply #6 on: November 27, 2006 - 12:20:50 PM »
The top bezel holder is staked under the indicator. It has to be broken off to take it off. If it is just the plastic handle, take them off then put a little silicone under them to glue them to the metal middle, before putting the screws back in. Gunslinger sells new shift indicators if you have to remove yours.
You did fix the engine or driveline vibration due to a bad balance job first right? Mu shifter used to rattle alot till I fixed my driveshaft and bad u-joint.
  • HvacMan
« Reply #7 on: November 29, 2006 - 11:14:58 PM »
haven't done anything with the driveline yet.
Got the fuel side all new from tank to carbs though, so that's a start.
Eric
Bay Area California
Offline ShelbyDogg
« Reply #8 on: December 01, 2006 - 06:13:22 PM »
I think you'll find that when you fix your vibration, your shifter will sit there nice and quiet. Have you ridden in a well balanced 4/speed big block combo yet to see how smooth it is? When  you do, you'll see how easy it is to cruise as fast as you want with the engine revving beyond 5k.
  • HvacMan
« Reply #9 on: December 01, 2006 - 08:57:57 PM »
what would be the best way to determine the source of the balance problem?
Eric
Bay Area California
Offline ShelbyDogg
« Reply #10 on: December 01, 2006 - 11:22:01 PM »
With the clutch depressed and the trans in gear, you're eliminating the trans, driveshaft, rear-end and wheels. Rev it up and if it isn't smooth, you have to look at your balancer, crank-rod-piston, flywheel combo. Has your engine been rebuilt by someone else besides you? Tell us whatyou know about your engine.
If it only vibrates at high speeds on the highway, you have to start at the wheels then move to the driveshaft.  jack it up and rev it in gear.
