Author Topic: Anyone doing a pro-touring project?  (Read 6974 times)
Offline chris5091
Re: Anyone doing a pro-touring project?
« Reply #15 on: December 02, 2006 - 12:52:45 PM »
thats the first pics i have seen of another challenger that color
Offline RusTy/SE
  • Just havin' fun
« Reply #16 on: December 03, 2006 - 12:30:39 AM »
My first Challenger, a 318 Rallye i owned from 77-90. Took me to many, many concerts :cheers: :drunk: :ylsuper: :thumbsup:
Here's some pics including my idea of a 73 T/A from the day i sold her... :walkaway:
« Last Edit: December 03, 2006 - 12:42:02 AM by RusTy/SE »
Russ
2001 Durango     1B4HS
1970 Challenger  JS29U
Offline chris5091
« Reply #17 on: December 03, 2006 - 10:54:20 AM »
is that a white top?
Offline RusTy/SE
  • Just havin' fun
« Reply #18 on: December 03, 2006 - 12:24:38 PM »
Yes i had it removed to go vinyl-less for the T/A theme  :)  After looking at pics of yours my wallet is feeling nervous  :naughty: That's really nice...you have to understand i experience temporary loss of reality anytime i see a 73 JY3 Challenger :screwy: :cheers:
A couple of more from when the top was deleted. New bumper fillers from when you could still purchase them through a dealer.
Russ
2001 Durango     1B4HS
« Reply #19 on: December 03, 2006 - 12:41:54 PM »
Russ,
  Why did you sell it? Nice car!!   :2thumbs:
Offline chris5091
« Reply #20 on: December 06, 2006 - 08:42:43 PM »
anyone else
Offline TrakHor
« Reply #21 on: February 04, 2007 - 03:50:29 PM »
I am, however it will be on a budget  :2cents:
By that I will probably fabricate a lot of items. I'm going to use wheels meant for a Mustang, an altered version of the 11.75 disc swap. I'm going to start work soon on a rear disc swap containing parts from a '94-'98 Cobra Mustang.
I will probably go to FirmFeel for most of my front suspension items, the rear is going to be a mixed bag of vendors.
17x9s up front, 17x10.5s
I'm going to try to give the car a European appearance.
I actually call my project a Pro-Track project. I say this because the mods I'm making are to make the car track worthy for the local roadcourses.
If it wasn't going to run the car on the track, I'd stick with 15" wheels, and go far less harsh on the suspension and make a crusier.
Jason
Offline cudabuyer
« Reply #22 on: February 05, 2007 - 05:47:18 AM »
sweet set-up travis, my car is at the body shop for engine compartment clean-up welding the holes closed from the removal of hoses and electrical clips, battery tray relocated to trunk, etc
return to mechanic shop in about 2 weeks for hemi install
still hoping for Power  Tour completion  :working:
70 Dodge Challenger Convertible 6.1 Hemi
« Reply #23 on: February 18, 2007 - 08:39:18 PM »
Well, I don't know that I'd necessarily call mine a pro-touring or a g-machine, but it will combine some of those elements along with a vintage trans am vibe. I will be using with a stock style suspension and 15" wheels, which is definetly not pro-touring. Down the road I plan to add modern seating, efi, OD trans, a/c and maybe a few other luxery type items for the modern aspects. Maybe waaaay down the road, I'll consider the 17" rims and coil overs, but not any time soon.
Suspension design is under way at the moment. After doing roll center analysis, I've got the ride heights set up where they'll work the best. The next step is to pull it apart and put it back together with the right combo of parts. 1.22 torsion bars, 1.25 adjustable tubular sway bar, fiberglass leaf springs, adjustable rear sway (haven't decided on best size yet), and some really good shocks. I'm toying around with the idea of building floating leafs and using a panhard bar to adjust rear bite, but haven't decided on that yet.
My new wheels recently arrived, 15x10 and 15x8 Aero racing wheels, so changes to the pickup points to accomodate 12" rear and 10" front rubber will need to happen. At first glance it appears moving the rear shackels in a couple inches and rolling the edge of the fender lips may be the only moves necessary. But, just in case, I've got a B body rear housing that can be swapped in to gain a little extra room.
Unlike most pro-touring cars, I'm not going with big block power. I can annihilate my tires now with my small block, so bother with even more torque. I'm also planning on moving the engine back about 4-5" and dropping it 2.5-3 inches down, which, unfortunatly, is going to require some custom work to the engien mounts and headers to maintain ground clearence. That should also help considerably with the weight distribution while I work at lightening it up. At 3550# my Challenger is the heaviest mopar I own.
Lotsa potential in E bodies. They are great looking cars.
« Last Edit: February 19, 2007 - 11:42:24 AM by HP2 »
Offline GreenFish
« Reply #24 on: February 19, 2007 - 10:32:23 AM »
I am sort of kind of doing pro touring, my unltimate goal is to have a really nice riding car i can drive anywhere in comfort. Right now, i am in the process of saving my cash for a hemi. I am thinking aluminum block 528. If you know a local engine builder that is good (like i do) it wont cost THAT much more than an iron block.
After that id like to go with an alterKtion and soon after that go to air ride suspension air bar in the rear and shock waves in the front. I already have the Keisler 5 speed.
This will probably take a few years cus this is a ton of money to spend. But that is the plan
