Author Topic: wiring harnesses (engine , tranny, light, and wiper) where to find them  (Read 2461 times)
Offline WVUFELLA
  • (OO/---------\OO) closest i could for a 72
hey guys does anyone know where i can wiring harnesses ? i need the engine and the headlight harness thanks fellas
Offline ShelbyDogg
Re: wiring harnesses (engine , tranny, light, and wiper) where to find them
« Reply #1 on: November 27, 2006 - 09:10:16 AM »
Buy, look up wires, ??   Year one sells them brand new.  Be careful if you get them elsewhere. I've found mixed up wires in the connectors from another company and lucky that the mix up didn't cause major damage or fire.
To look up wiring diagrams,  MYMOPAR.COM has some diagrams under the "mopar wiring diagrams" section under the "Electrical Specs" section.
Offline WVUFELLA
« Reply #3 on: November 27, 2006 - 11:35:00 AM »
thanks cp that was the only place i had found them thus far. just wanted to make sure that they were correct my car is a 72 original 318 now it ha sa 440  will that make any difference in the wiring??
Offline ShelbyDogg
« Reply #4 on: November 27, 2006 - 12:13:56 PM »
Wiring is different for a big block and small block. Placement of the coil, distributor electronic or points for ealy or late '72, horn and washer pump placement, etc.
Rewire yours with the correct ends and longer wires or buy the correct big block one.
« Reply #5 on: November 28, 2006 - 01:31:26 PM »
Evans should have a custom big block with Electronic ign for a 72
Offline camjam
  • Rare-it-T
« Reply #6 on: November 28, 2006 - 06:12:59 PM »
I will never buy from Evans again.
I ordered the wiring harness for the engine. They wired the connector at the fire wall in reverse. It took me a long time to figure why the car wouldn't start when Iturned the ignition key. It was by accident that I noticed the key would turn on the headlights for an instant. When I tried the light switch it started the engine.
When I called him he didn't apologize or anything. He said maybe he will check the other harnesses he had in stock.
Not a good experience.
71 Challenger R/T 383 4spd - 1 of 10 known to have been built for canada - restored
70 Charger R/T SE 440 auto - restored
« Reply #7 on: November 28, 2006 - 06:28:02 PM »
I guess we acn all have a bad day , probably had a flunky wiring them looking at the other side of the bulkhead connector
 but he could have treated you better for sure
Offline ShelbyDogg
« Reply #8 on: November 28, 2006 - 09:59:20 PM »
Those are the same people that I wouldn't buy from either. 2 wiring problems with 2 different sets of wires from them. The guy must be color blind.  Pay the extra money and get it from Year One.
