Author Topic: Challenger hood pin installation  (Read 5637 times)
Offline AMXguy
« on: November 27, 2006 - 07:59:33 PM »
 Is it as tough to drill the holes in the hood as it looks like it would be ? getting the angle of the dangel correct looks like a nightmare, or do you drill a big enough hole to allow for a small error?
1970 R/T SE Challenger
 1970 Superbee
 1969 S code Mach 1
 1967  GTO
Offline 72hemi
  • MEMBER SINCE JANUARY 2006
Re: Challenger hood pin installation
« Reply #1 on: November 27, 2006 - 08:24:04 PM »
What I would reccomend is to lay down painters tape and mark the hole. Then use a step drill bit. They seem to work the best on sheet metal. Using the tape doubles as a protector of the painted surface to help minimize chipping and peeling. So far has work for me with hood pins and spoilers. Hope this helps.
1996 Dodge Viper GTS Coupe
Offline Challenger1970
« Reply #2 on: November 27, 2006 - 11:44:23 PM »
I think that most hoods have marked holes on the underside
« Reply #3 on: November 28, 2006 - 03:30:50 AM »
It's not that tough to do. The holes for the studs are already drilled in the inner front fenders. There are cut-outs, so to speak, on the underside of the hood too. Yes, you do have a margin for error, as you will have to make the holes in the hood slightly larger than the stud. I can post pics later of mine, if you'd like.
Offline AMXguy
« Reply #4 on: November 28, 2006 - 08:01:05 AM »
 I see what you're saying, I thought if you had to drill clear through the hood the angle would be tough but just drilling through the skin wouldn't be a problem. a close up of the right place to put them on the fender I would really like to get if I could though. also there are choices on cable length does anyone know which one is correct for a Challenger?  thanks
 1970 Superbee
 1969 S code Mach 1
 1967  GTO
« Reply #5 on: November 28, 2006 - 09:25:18 AM »
I don't know what year Challenger you have, but the holes for the studs were pre-drilled for 70-71's. The lanyard lenght is 18" for all Challengers. I hope these pics help you.
Offline AMXguy
« Reply #6 on: November 28, 2006 - 09:35:35 AM »
 Mike thanks a bunch that's great, it's a 70 so it shouldn't be that bad. I love this site! I don't know how anyone could restore a car properly without help from a forum like this, and all this time I heard Mopar guys were snobs.
 1970 Superbee
 1969 S code Mach 1
 1967  GTO
71challengher
« Reply #7 on: November 28, 2006 - 11:27:47 AM »
The only thing Mike didn't tell you was to make sure your fenders and hood are lined up.
« Reply #8 on: November 28, 2006 - 03:18:37 PM »
... And how would you know that Jackie?    :poopoke:  :poopoke:  :poopoke:
P.S. - AMXguy, I am not a snob.  :grinno:    :lol:
Offline Challenger6pak
« Reply #9 on: November 28, 2006 - 05:17:14 PM »
:iagree: Once the pins are in the adjustments are pretty hard to do.
71challengher
« Reply #10 on: November 28, 2006 - 07:06:50 PM »
I know, because that is why my hood pins aren't on yet. First I need to save up about $500 to send it to the body shop. They have to rebuild  my hinges. Then line up the doors, fenders and hood. Then he can mount my hood pins. And,who told you where the access holes in your hood were. :poopoke:         Amxguy Mopar Peoples aren't snobs. Just ask the owners and the staff of Carlisle. They look forward to the Mopar Show every year because they love the people. :2thumbs:
Offline AMXguy
« Reply #11 on: November 28, 2006 - 10:43:52 PM »
Hey just kidding about the snob thing, too many years as the red headed step child with my AMC's I think. most car guys are good people but I have to say this forum seems the most helpful and upbeat I've seen yet.
 1970 Superbee
 1969 S code Mach 1
 1967  GTO
