Dana 60 Identification
Author Topic: Dana 60 Identification  (Read 1146 times)
Offline 74 340 4speed
« on: November 28, 2006 - 09:11:19 AM »
Is there anyway to tell what gears are in my Dana 60 without removing the cover and counting the teeth on the ring and pinion?  GM stamped their housings on the axle tube so I was able to determine the ratio in my Camaro from that.   Are their any stampings like that on Danas?
Andy
1967 Camaro SS: 406 sbc 505 hp/506 ft lbs|4 speed|Posi|3.73s
1969 C/10  350|Turbo 350
1969 Dodge D300 318|4 speed|Dana|4.88s
1972Nova: 350|Turbo 350
1974 'Cuda: 340|4 speed|Dana 60|4.10s|posi
1999 Camaro SS: Auto|Longtube Headers|True Duals|TT2s
2013 Challenger R/T: 6 speed|Hurst with pistol grip|mopar performance exhaust|super track pak
Offline Tubbed440
  • Suspension NinJa
Re: Dana 60 Identification
« Reply #1 on: November 28, 2006 - 09:30:14 AM »
Yep.  If it has a posi unit, it's alot easier, but you can still do it with an open diff.  Jack up the rear of the car (so the tires are off of the ground) and put the trans in neutral.  Place a mark or tape on the inside of both tires, pointing straight to the ground.  Also, place a mark on the drive shaft.  Now, turn the drive shaft until the tires make 1 complete rotation, and count how many time you rotated the drive shaft.  If it's an open diff rear, you may need to remove the tires and brake drums so the brakes won't drag.  What you're shooting for is both axles to rotate the exact same amount, so you can get an accurate count.
ex.  Tires rotate 1 time and you turned the driveshaft 3.5 times.  This means that you have a 3.50-3.55 rear gear.
On the tag question:  if no one has removed it, or changed the gears, there was usually some kind of tag on the bolts of the rear cover that identified the rear gear ratio, but if you're like me, luck would have it that someone has removed it. :jumping:
« Last Edit: November 28, 2006 - 09:32:12 AM by Tubbed440 »
74 Dodge Challenger
500 inch stroker, Full cage, ladder bars,
coil-overs, 4L80E, 325/50 M/T DR's....street car!
(work in progress)
« Reply #2 on: November 28, 2006 - 01:49:06 PM »
with an open diff yuo can jam one wheel ,count the # of turns of the driveshaft to get the other wheel to turn 2 rotations
Offline Katfish
  • 70 Challenger
« Reply #3 on: November 28, 2006 - 05:46:38 PM »
Check out following
Offline 1BADFISH™
« Reply #4 on: November 28, 2006 - 07:06:37 PM »
YOu could get a dana in '74?   :clueless:
Charlottetown, PE
2014 GMC Sierra Crew Cab White Diamond edition.
1970 Dodge Challenger 340-6 4spd.
*Member Since* Oct 11, 2005
« Reply #5 on: November 28, 2006 - 07:43:26 PM »
possibly as an A code Track Pack, anyone ever seen one ? Barry would probably know for sure
Alaskan_TA
« Reply #6 on: November 28, 2006 - 10:15:04 PM »
I have very little info for 1974. If you find an original Dana 60 in a 1974 model I bet it is a truck though.
Barry
« Reply #7 on: November 29, 2006 - 07:04:50 PM »
Rear came from a 70 440 Six Pack Challenger that was totaled.  Thanks for the #s Katfish, that will help me alot!
« Last Edit: November 29, 2006 - 07:21:18 PM by 74 340 4speed »
Andy
Offline pettybluecuda
  • www.cudaregistry.com
    • 70-74 barracuda-cuda' registry
« Reply #8 on: November 29, 2006 - 11:16:27 PM »
I know of a car just north of me a 74 challenger and it came with a dana in it. I didnt think it was wright untill I checked it out.
