The good news is that I got my new fuel pump installed and she started right up.
The bad news is that after 5 miles she died on me.
After three breakdowns in the space of 2 months, I've had enough. I've obviously got crap in there that keeps clogging her up and rather than mess around with trying to clean it out, I've decided to just go with new.
Enough is enough.
The car is a '73 Challenger with a transplanted '68 440.
I'm thinking that I'm going to set her up like a '70 v-code car.
Gas tank without EEC
Fuel sending unit 3/8
Main fuel line 3/8
Return line 1/4
Carter M4845 fuel pump 3/8
Vapor seperator/fuel filter
Does this sound about right/complete?
And just so I'm clear on the function... on the vapor seperator/filter, the 3/8 line goes to the carb as with a normal filter, but the 1/4 inch return line goes back to the tank and dumps out into the second smaller nipple on the sending unit... no?
Also, I've seen "return" and "vapor" lines mentioned, but I'm not clear on the differences. Can someone explain?
Many thanks, as always. :-)
Also, also: Is it worth the extra expense to go stainless?
