Author Topic: 1971 charger build sheet roof decode?  (Read 1433 times)
Offline pettybluecuda
  • www.cudaregistry.com
    • 70-74 barracuda-cuda' registry
« on: November 29, 2006 - 10:11:03 PM »
hi all,
I have a 71 charger and im looking over the build sheet and under the code (roof-pnt style top) it says "GY9" What is that?
Alaskan_TA
Re: 1971 charger build sheet roof decode?
« Reply #1 on: November 29, 2006 - 10:13:12 PM »
It is the paint code for the roof, Dark Gold Metallic.
Barry
« Reply #2 on: November 29, 2006 - 10:18:10 PM »
thanks Barry. It was getting me confused, because it look like it had a factory vinyl top, the pins are there and the trim but the top is missing. Did they have a painted top with just the trim? strange.
Alaskan_TA
« Reply #3 on: November 29, 2006 - 10:23:10 PM »
Is it a two tone car? Scan the sheet and email it to me if you like, that would be easier for me if I can see what you see.
Barry
« Reply #4 on: November 29, 2006 - 10:29:00 PM »
I would but all I have is the top right corner about 4 inches by 2 inches. all I have on it is the half of the vin on  the sheet down to the v stripe. If I had a scanner I would send it anyway but I have yet to pick one up
Alaskan_TA
« Reply #5 on: November 29, 2006 - 10:37:45 PM »
OK, so it is torn off left of the GY9 code?
« Reply #6 on: November 29, 2006 - 10:41:49 PM »
Yes it is, Ok on the sheet all I have under the vin is
 L1G 145854.... BUILD CODE U  SOLD CAR 14
 UDF Y4...PAINT STYLE VO1...BODY PAINT GY9...ROOF PNT STYL TOP GY9...
V STRIPE 6X
 I hope that help! Thanks again barry
Alaskan_TA
« Reply #7 on: November 29, 2006 - 10:45:24 PM »
OK, not a two tone car then. It has the V01 and the body and roof paint codes are the same.
Barry
