Author Topic: T/A PARTS & PART NUMBERS PLEASE HELP!!!!  (Read 1377 times)
Offline ozrt4406
« on: December 04, 2006 - 05:55:44 AM »
HEY YOU GUYS I NEED SOME HELP.... WHAT ARE THE CASTING NUMBERS FOR T/A EXHAUST MANIFOLDS??? DO T/A'S WITH POWER STEER HAVE P/STEER OIL COOLERS AS STANDARD??? THANKS AGAIN. :feedback: OZ
T/A AND R/T............... IM GREEDY.
Offline FY1443433
  • 1971 Superbee, 1970 Challenger R/T
Re: T/A PARTS & PART NUMBERS PLEASE HELP!!!!
« Reply #1 on: December 04, 2006 - 06:57:54 AM »
ozrt4406,
Try this web site:  www:transamcuda.com
FY1
Alaskan_TA
« Reply #2 on: December 04, 2006 - 04:32:01 PM »
Yes on the power steering cooler.
RH manifiold is casting number 2863549
LH manifold is casting number 2863553
They are the same for any 1970 340 weather from a Dart, Duster, Challenger or Cuda. The manifolds from 1968-69 will also work, but the driver's side has a large embossed casting number on the earlier one, but some of the early style were used in 1970 as well.
I may have a passenger side one here, I will can look if you need one?
Barry
« Last Edit: December 04, 2006 - 04:33:34 PM by Alaskan_TA »
Offline ozrt4406
« Reply #3 on: December 05, 2006 - 01:38:44 AM »
yes thanks barry i do need a pair of manifolds , obviously a p/steer cooler ( i think all of it ) and how do i get a copy of your cd??? postage would be to australia. .can you email me with a phone number so i can ring you direct , your time.thanks ian
Alaskan_TA
« Reply #4 on: December 05, 2006 - 05:02:16 PM »
OK, I will look for the manifold, I should be able to find it in the next few days. My phone number is 907-225-2709 but you can email, I am sure it would be cheaper for you.
T/Ake care,
Barry
Offline Transamcuda.com
  • Numbers cruncher and expert at nothing.
    • Transamcuda.com
« Reply #5 on: January 26, 2007 - 03:09:17 AM »
You can check here for a list of parts and casting numbers I have listed. If you need any other info just shoot me an email.  :2thumbs:
http://www.transamcuda.com/Part & Casting Numbers.htm
Dont forget to register your AAR at the AAR Registry only at www.transamcuda.com 1981 AAR's on file. Also info on 70 thru 74 E-Bodies. Ask me about yours!!
Offline ozrt4406
« Reply #6 on: February 02, 2007 - 10:04:07 PM »
I SHALL DO THANK YOU!!! :2thumbs:
