Author Topic: small yoke driveshaft...would you trust it?  (Read 1434 times)
Offline dwbiggs
« on: December 04, 2006 - 04:01:27 PM »
With the combo listed below...would you trust a small yoke to handle the HP and drag radials on the dragstrip?  This is the original driveshaft from the small block setup.  Also, will an 8 3/4 489 cone style rear hold up with drag radials?
Dan
Offline tactransman
Re: small yoke driveshaft...would you trust it?
« Reply #1 on: December 04, 2006 - 08:07:23 PM »
I ran my stock small u-joint driveshaft in my Challenger to  11.80's with the juice and 10 inch slicks with the front left tire about 6 inches off the pavement. But............bigger has to be better. :grinyes:
Terry-tactransman
Union, Mo.
« Reply #2 on: December 04, 2006 - 08:12:55 PM »
Yes I would and have. The driveshaft would probably fail first. It's better to go bigger tho. And you can buy solid joints too if you want. But for a safety concern....It's Christmas time so what's Santa bringing you?
« Reply #3 on: December 05, 2006 - 01:02:13 AM »
Most fo the truck Danas use the small 7260 yolk , But I will still prefer toi have the 7290 joint in there
Offline moper
« Reply #4 on: December 05, 2006 - 06:35:27 AM »
I've done it too. But, when possible, I'd upgrade.
Offline TreeFrog
    • TreeFrog
« Reply #5 on: December 05, 2006 - 01:42:09 PM »
use it till it goes...if your concerned not that it would be a bad idea for a drag car or any car add a ... crap one of those thingies that the drive shaft goes thru that keepis it from falling and getting launched thru your bottom.... Safety Loop?  I think they are called..I imagine someone makes them for the E-body, if not you can buy or make a universal.
87 Dodge Ram     318 Blue
88 Dodge Ram     360 Grey (+)
Offline TreeFrog
    • TreeFrog
« Reply #6 on: December 05, 2006 - 01:51:54 PM »
« Reply #7 on: December 05, 2006 - 03:26:50 PM »
Us car tool / John has a nice driveshaft loop that bolts to the trans cross member
Offline TreeFrog
    • TreeFrog
« Reply #8 on: December 06, 2006 - 02:29:43 PM »
thereya go!
« Reply #9 on: December 06, 2006 - 05:43:01 PM »
same piece
Offline dwbiggs
« Reply #10 on: December 07, 2006 - 08:20:17 AM »
dunno if that will fit...my TTI pipes run very close to the driveshaft.  Guess it depends on how big the loop is.
Offline moper
« Reply #11 on: December 08, 2006 - 10:33:21 AM »
You may need to modify the exh to fit that loop with TTi stuff..
Offline dwbiggs
« Reply #12 on: December 08, 2006 - 02:07:12 PM »
Or just tack a strip of metal between the pipes.
« Reply #13 on: December 08, 2006 - 02:08:27 PM »
Make sure the pinion angle is correct , it should be 4-7* nose down from the driveshaft , having that set properly takes a LOT of load off the U joint
