Author Topic: AAR Neon  (Read 3921 times)
Offline IUU2ROC
Re: AAR Neon
« Reply #15 on: December 07, 2006 - 05:39:47 PM »
I coulda swore that was 3 3/4" on the Neon. I even squinted and everything.  :eek4:
I found some specs on the internet that shows the wheels should fit.
This website shows the 5 bolt Neon had 100 mm bolt pattern
http://www.sromagazine.com/shop/wheelguide.html
Quote
Dodge Neon (all) 1995-1997 (4x100mm / HPO / 12x1.5 Lug-nut / 57.10mm Bore)
Dodge Neon (all models) 1998-up (5x100mm / HPO / 12x1.5 Lug-nut / 57.10mm Bore)
Dodge Neon (5x100) 1995-up (5x100mm / HPO / 12x1.5 Lug-nut / 57.10mm Bore)
This website shows small bolt pattern Mopars were 4 inch.
http://www.alliedracingwheels.com/patternref.html
Quote
5 on 4 (101.6 mm)
'64-'69 Mopar "A" 13"
'65-'76 Mopar "A" 14"
Dodge - Aspen, Dart, Demon, Swinger (w/o discs) '63-'72
Plymouth - Barracuda, Duster, Valiant (w/o discs) '61-'74
Now I think I know everything. Well, maybe not as much as my teenagers, but almost everything.  :-\
Offline DodgeFreak
  • Cars and trucks are my friends..
Re: AAR Neon
« Reply #16 on: December 07, 2006 - 06:41:09 PM »
the neon and the shadow have the same bolt pattern its not a 1\4 of an inch off...its closer than that...but it is off just alittle but you can get the rim to fit on with out drilling.. the only "major" difference is the center hole for the hub its about 3\4 of an inch off...i took a die grinder to it to get it to fit on the duster...but if your putting it on the neon it won't matter.
74 Plymouth Duster- restoring
77 Dodge D150 shortbox- as long as i don't change my mind will be a step side dually diesel or a 383 powered truck
04 durango 4.7
